a new kind of visible radiant energy?
Started by david lambright, August 17, 2010, 04:01:43 AM
do you like this topic?
yes, i will tell others about it
 no, it is BS
cletushowell
I figured the principle of joe cell
were doing things back wards when a light fillament is broke
the current does not jump the gap but if you strect the metal
it creates it own magnet pulling the metal fillanent together
i broke the glass this is how joes cell is working snow flakes attrac
with little power were running everything back wards
magnets pull harder then they push when they pull
the piston up then it discharges the magnetism
the.next piston is building energy fartgesr away
this is the principles of my aletnating capacitors
they all charge tge same but discharge
them in order you get high voktage useable current from a low wireless power supply
tagor
Quote from: nievesoliveras on August 29, 2010, 09:37:54 AM
Maybe this one is out of place but who knows.
There are so many inteligent people in this area, that I will post my question here.
I want to run a motor that has three cables going out of it and it has a common point where the three ends of the coils that has the three cables are together tied.
How can I run that motor with a pulsing circuit that energizes one coil at a time?
A drawing that I posted on another thread is here:
Jesus
hello
this seems to be a brushless dc motor ( like DD and CD motor )
here is a pdf :
http://www.freescale.com/files/dsp/doc/app_note/AN1961.pdf
gravityblock
Quote from: Rosemary Ainslie on August 18, 2010, 04:32:28 AM
The implications are that this may be a result of some kind of gravitational influence - precisely because it appears to 'bend' light.  But other strange effects are that it induces a magnetic response in material that is not traditionally known to have magnetic properties - string - rocks and such like.
I'm going to try this again.  If there is a magnetic response in materials that are not traditionally known to have magnetic properties, then we need to measure this force.
We can measure this force with the Baker's device I mentioned in my previous post, by substituting the magnets which are attached to the nylon string with a non-magnetic material, or do tests with the magnets attached to the nylon thread.  If there is even a slight magnetic response of the non-magnetic material inside the Baker's device when held over David's PMH, then it will be clearly seen and the force can be documented, measured, and studied in more detail.
If there is a magnetic response in non-magnetic materials, and the force can be easily measured, then this will catch the attention of the scientific community.  There is a possibility of the earth having secondary magnetic fields, which has yet been discovered, and there could be an interaction between David's PMH and the theoretical secondary magnetic fields of the earth, or other possiblities.
I offered a simple experiment on the energeticforum to validate David's claim of feeling a repulsive force when pointing a laser pointer at the PMH, but the test was never done.  If a repulsive force could be felt, then the experiment would easily show the laser pointer being deflected.  It wouldn't surprise me if the Baker's test is not done also.
GB
cletushowell
If you have been threatened by mib
send it to me i have no kids im not afraid
of these fuckers and have a lot of shit on
them all and technology they can only dream of
so what im saying is build a fake email
dont put your name and either link me two it
or give it direct I will do my best to decode it
and put it with the rest of others and release it finished
free thats the only way to beat these guys
ch@helpuflip.com
Rosemary Ainslie
Quote from: gravityblock on August 29, 2010, 12:19:18 PM
I'm going to try this again.  If there is a magnetic response in materials that is not traditionally known to have magnetic properties, then we need to measure this force.
If there is even a slight magnetic response of the non-magnetic material when held over David's PMH, then it will be clearly seen and the force can be documented, measured, and studied in more detail.
GB
Hi gravityblock.  I saw your post and I started reading the link but have not really had time to study it yet.  I see that an amateur has found a way to measure subtle gravity fluctuations which is a very good thing.  Thoroughly approve of any attempt at making actual measurements but I'm not sure that I, personally could put that apparatus together.  I'll get back here soon.  Am knee deep in trying to finish the magnet arrangement that I'm working on and I want to try and photograph this before I go out.   I absolutely agree that this needs proper measurement and proper validation.
Jesus, I can't help you at all - delighted to see tagor rally.  And many, many thanks for doing that chore on Jet's pictures.  Jetjis is a genius experimentalist and frankly I'm delighted that he's here.  Let's hope he has the time to post on both forums.
Gravityblock - I've followed your ideas and your interests through these forums for a while now.  I believe there is much we could discuss.  But I'm still battling for time.  I think I've spread myself a bit thin at the moment.  I'll try and give that reference of yours more attention.
Kindest regards to all
Rosemary
