Thanks to ALL for your help!!
a new kind of visible radiant energy?
Started by david lambright, August 17, 2010, 04:01:43 AM
do you like this topic?
yes, i will tell others about it
 no, it is BS
Hope
David,   Thank you!   This is idea is making many of the inventions and projects here tye into the mag theory of Ed Leeds......  Bending light with only shapes            that is KISS!   Nature uses this method as the DEFAULT why can't we?  Our projects need a baseline.    Why not set our OWN current limit?   I mean why ever use more or experiment with more than you would be willing to use daily to complete your goal?     if you place a small bulb into the input circuits then you will limit the current flow as you change the blub values.   Then you can begin to check what is acceptiable and what is "over limits".
sm0ky2
@ Dave
im am particularly interested in this effect while the ring is stationary. not spinning.
It still persists, all-be-it much less intensly.
its kind of "hard to see" on the video. i was wonderng if you could talk more about this field.
it didn't appear to be "static".  was that an effect of the camera? or does that field actually move around, as if it is reacting with everything around it?
also, have you tried turning it over? so the other side (+/-) is facing up? if so, what differences did you observe?
david lambright
hi smokey...this wave like distortion radiates off my devices 360 degrees...even when stationary this is going on....what i see is like a heat type wave with out the heat...it interacts with every thing around it....quartz crystal we know is an oscillator having its own frequency...is this distortion what causes quartz and every thing else to vibrate?...david
Hope
So if everything is vibrating, due all things have poles?  So far "standard science" teaches us about differences in potentials and seeking balance.  This device will be a build for me also.   I will post results and try to capture it better on video.   Wondering if two of these devices in-sync or opposition would build on effect?  Stacked?  This will be a fun one!
david lambright
hope, i do not know the answer to that .....from what i have been reading, electrogravatic  effects made with high voltages are dangerous.....what if my devices can reproduce the effects without the dangerous by-products?   this is very, very interesting to me.....thanks for your interest also...david
