a new kind of visible radiant energy?
Started by david lambright, August 17, 2010, 04:01:43 AM
do you like this topic?
yes, i will tell others about it
 no, it is BS
nievesoliveras
Thank you @lambright!
The device arrived today and it is under test.
Jesus
david lambright
jesus...the secret ingredient is black iron oxide, Fe3O4, from alpha chemicals.com.....david
nievesoliveras
Quote from: david lambright on August 31, 2010, 04:11:22 PM
That is why it is magnetic then.
My question is: It is the metal tube aluminum?
Jesus
david lambright
jesus, yes it is aluminum, but i believe that it is the oxide that is radiating....my ferrofluid core device works very well...my next device will be a Leedskalnin shaped device, using the oxide as the core material, mounted over an iron block similar to Eds device......david....added;...the effect i describe is very subtle, but once you see it, it is unmistakable....like if you dipped the ring into bubble solution.....the film that remains.....if you turn the ring slowly...my friend joel was viewing the device against  a window with mini blinds which seemed to work well....david
sm0ky2
@ cletus
i still cant send PM's for some reason.. i hope stephan gets back soon so he can fix that....
you can email me if you need to:  Sm0ky2@aol.com
i dont think im able to quite grasp what you are saying..
is this close? or did i take that in completely the wrong way?
