a new kind of visible radiant energy?
Started by david lambright, August 17, 2010, 04:01:43 AM
do you like this topic?
yes, i will tell others about it
 no, it is BS
cletushowell
Rose i sent you a priivate message
nimrod was never once degraded by God he not only has power over hell
a place God cannot go but he gets a axis exactly parralle
to heaven a exact oposite he said to be a mighty hunter
and deceives even 1/3 the angles the path is straight and narrow
you see mathew 7:14 few will find it
7/3 2.3333 I gave you the answer
marco has power and a lot of it
dont wory devil went down to georgia
for you
there a long way till me and him go to war
and God said there would be war but its also the prince
job to declare peace a war does not mean millions die
be fruitfull and populate the earth
but bible is full of war grandpa did a lot of work with geneva
treaties and theres only a few not playing by the rules
cletushowell
Ill corect you again and defend marko
have you seen marco wire a coil
have you seen marco with a coil
marko did not build a coil
marco built eithe a optic crystal or a optic crystal with a plasma
similar to the magnifyer glass with
the neon thru it but the numbers represent cuts on the crystal
you cannot land on the sun and drink ice tea with wires he specificaly tells you that the coil was put out by the goverment and when he found out he was a little upset but glad that people were listenening
its like my flyiny triangle i fixed the polarity
on i couldnt build it but the goverment did
and landed it in my hometown on
aug 22 but i was not there in fresno i was at my shop in bakersfield
what we can do is limited to our help
marco has a lot of help now and technology is moving extremly fast between me and him if you knoticed everything
has picked up in science im about 3 months its no longer stuck
like it has been since tesla died and
were not yet in goverment but i will be
God said Im to be the leader of the west
read the bush scrolls you will see
sm0ky2
here you go rose
that was actually helpful, i see something i overlooked before..
cletushowell
Smoky you got the pattern its just complicated because the second ring is off
a bit im going to Give the answer to rose
then rose can correct the rings
Or you can try spin the outside ring
till the circles line up 34543
sorry I dont have the programs you do
this should start your pattern of either a bit bigger or a little bit off
this is seperating your prontons and electrons and building your next ring
cletushowell
Remember i said the pyrramids
intersect you see when you spin it
32123
then imaginge the 123 the other way
bout the 3 is the base 2 is past center
1 is the peak
Then reverse 321 again
its pefectly symetrical over the 1
something rodin could not do
