a new kind of visible radiant energy?
Started by david lambright, August 17, 2010, 04:01:43 AM
do you like this topic?
yes, i will tell others about it
 no, it is BS
cletushowell
Im stuck on lead to its my problem in this video
why lead
i made a salt battery had 12 volts from a antenna i thought i busted the wireless energy i had it so simple just wires straight to the
salt from the cardboard cylinders a little water
had good voktage took it all outside to show everyone my great discovery
never worked again no joke everything always works like that
for me like today i levitated the whole
plastic in this video but dont know how
but my cousin watched it levitate was weird but doing it twice
maybee one day Check out this video on YouTube:
http://www.youtube.com/watch?v=ehgshGOfKgI&feature=youtube_gdata_player
Sent from my iPhone
Hope
Would it stand to reason that if the PMH can magnetize non ferrous then it possibly magnetize light as well? Between any two different poles there would seem to me to exist a barrier or neutral, zero area even when a magnet is barred the barrier is still there but only very close or what do you all think? Else there would be no pole differences?? So Rosemary your exactly correct when you said NOTHING else would.   Neutral fields are so strong they even can separate poles when they are very thin.  Correct? Now that may be another key.
Hope
Thank you all for discovering that Cletus wasn't just someone using a "story writer" and cutting and paste'in our responses to generate more context.   His number of posts alarmed me.   I did watch your recent youtube Cletus,  glad you stayed.  I thought you were of topic because it was so different.  But as may be this science is DIFFERENT too.
Thank you, for I also re-read your replys and have be helped as well.
Rosemary Ainslie
Quote from: Hope on September 02, 2010, 04:48:48 AM
;D
Hope
I am still awake, and have one possible use for Lambrite Focus, if we placed this core (made small ones ) around the back side of a magnet, then when a stator was passing the zero focus would possibly negate the back attraction.  If only it were that easy.
UPDATE:  The pipe ring locked when we used 12 gauge wire and car battery  (Ours is about 17 inches inner circumference ) We placed a small magnet in center hub  and placed suspended toroidal shaped magnet on nylon lite thread.  When we energized the coil (13 turns)  the suspended magnet spun like a bat out of hades, then we unlocked the ring and reverse the coil charge, it spun the other way at what looked to be the same speed.
After a long gyration period (3-5 mins) it came to rest but then we discovered the small magnet below was repelling the small magnet above and it made it off center a bit when at rest....   which seemed to vibrate at any sound or wind outside.
Night All!
