a new kind of visible radiant energy?
Started by david lambright, August 17, 2010, 04:01:43 AM
do you like this topic?
yes, i will tell others about it
 no, it is BS
cletushowell
Wow that was a very good picture it explains it in simple terms
the light spins the string till it maxes out the strings ability to spin
then one of two things can happen either your stuck in so called
neutral stored energy you can reverse the spin by cutting the light
or you can use the free energy at the end of the string and it will continue to spin now how many winds in the string before you use it depends on your torque now supper conductors or insulators hold energy longer
like fiberglass i noticed fiberglass is made of string but some how that fiberlass stores energy to discharge to the black light so it absorbes energy say static and discharges it when theres no light no window
its like the string in some way maxes out during the day carries you thru the night but light is frequency I moved that light bulb in the shade
in the tub and also using a rodin type coil moved the black light
also with like those glow tubes i think i posted that here
already
david lambright
this is mylatest post at EF....................... hi everyone...
jet, did your mail come?...jesus at OU was having a hard time seeing the radiation, but he did start to see it, finally!..do not be discouraged if you do not see it right away....remember what bruce said....very very subtle.....this is a little frustrating for me but like i said before, if this were easy to see/detect, it would have been discovered long ago....so far i have not seen any good photos of this effect, only good descriptions,fortunately from Tesla and other researchers, that lends a little credibility to what i am describing and trying to capture with imaging devices....these distorted "fields" around my devices, seem to be present around high energy/high magnetic fields and seem to be variable...i would still like to use some type of FLIR imager, to see if that might capture it better....these effects are real...the visual/gravitational anomalies are not imagined....similar effects have been seen/documented by some of the biggest names in this field...i know we are getting close...elusive? HA! frustrating? double HA!but i know what i have seen/felt...i have shown my devices to over 50 individuals who verify my findings....this is all very new to me...i am trying my best to help others to experience what i have, so that other researchers may find the root of these effects....how does one go about describing something they have never seen before?....if it were easy, i would not talking about it right now, it would already be old news......thanks for your help, even taking the time to read these threads, helps...i am not really that smart, i never went to college, i do not hold any degrees, i got my GED while in prison!....this i do know, i have seen/rediscovered something important....i have created it without the high voltage/magnetism that is normally associated with these distortions/anomalies....these effects are very subtle right now but most of what i am doing is still very crude, but i am moving forward in my progress.....david
cletushowell
Dave in science you either start in prison or end in prision
the reason is mistakes cost a lot of
people harm mistakes are from unknown
gernoble haiti haarp
your work is leading the way to the future
as I have found all things go back to earth
when you stand in the forrest theres no
difference between a degree from harvard and
a ged everything comes from the forest
evertything built is amazing from
the trees the dirt the plants now did
all these go to college no i have college
i have high awards but i can tell you that
a lot of what i was taught got in my way
of understanding the basics even electricity
thru a wire vs around it in jail over
my eartg battery i figured out the gravity demonstration
im working on improving that i stuck
between whats more important
free energy or gravity or is free energy gravity
is the joe cell free power the car because its antigravity
is it because he taping the gravity
theres a link between free energy and gravity
im im over my head frustrated how do we link wireless energy to the gravity
ice does not float with wires
its stored energy but its colder then the water
but heat rises that defies logic
im sorry how does oxygen overcome the temperature
ice is denser then water so its more compact
the water the key to the ice is the key to
everything why tesla shattered the glacier
its the key the ice caps on the poles sorry if im off subject i think
its the answer the radiant waves of the ice
its a crystal its creating its own energy
some how that makes it float that overcones the temperature
change when you create ice its removing energy
or is it polorising the crystals oxygen is trapped on the botom layer the
penguins live off the oxygen using the ubderwater cameras
they proved they make dips in the ice to gatther the air bubles
to give them ability to breath under ice for a long time
those air bubles float the ice where is the hydrogen in ice
if water is h2o you condense the h20 to what
if you expand it your seperating hydrogen and oxygen
can the ice reverse the hutchesion crystal
but taking the energy from the crystal
to the ice maybee you dont know maybee you know
one part please email me ch@helpuflip.com
if i can understand the ice I think I can put
everything together ill reasearch it
and see also i need help with light bulb gas pressure
to understand the radiant energy is absorbed into the gas
the amount of gas pressure or vacume
intereferes or accletates the light - energy transfer
wow this is pretty indebt sorry I know theres like 1 or two people that can help me.
david lambright
jesus, thank you!.....could you describe what you see?....and smokey2, i would like to copy your version of the device...it seems to have a good output of this radiation...thanks everyone for your help....david
sm0ky2
Quote from: nievesoliveras on September 02, 2010, 12:14:18 PM
the compass needle begins to vibrate up and down.
@ Jesus,
thank you. that's the confirmation i was looking for.
