a new kind of visible radiant energy?
Started by david lambright, August 17, 2010, 04:01:43 AM
do you like this topic?
yes, i will tell others about it
 no, it is BS
cletushowell
Man rocks take a lot of energy im at about 180 degrees
when it crosses boiling point it should lift
but what is so weird is my lazer temperature
reader is measuring the temperature lower away from the rock even though
its directed to the rock there is some kind of
radiant energy chage feild between the rock and about five feet away
that it spins the magnet but also
thats about the distance of this temperature difference it goes from 140-180
depending on how far away i am from the rock
has anyone done temperature on daves device using a lazer and see if the feild distancd measured changes the reading this would actualy be the measurement of the feild but i think you need to have a high moisture content to show the temperature in the feild just a observation im getting tired all day trying to levitate this rock
from yesterdays experinents to the rock
the rock has its own characteristics
you know rock are alive they live they breath
they use and absorb moisture if you burn a rock it dies you killed it
me im animal testing beings rocks are alive
thats ok its testing on me shocked my ass good like 10 times
burned my wires in defiance told me it didnt like to much salt by
throwing my breaker like 20 times
so i gave it a bath started over its home was to big
these rocks are picky you know they only like to lay a certain
way they dont like hammers and even though i wanted to do surgury like edd i didnt have my diamond blade so this one is still in tact
but if it doesnt float soon after a whole day of pampering it
im going to destroy it
it must be a Girl needs lots of time getting ready
needs everything perfect then finaly about ten hours after you want the rock to leave the house/water it decides to either go
or just stay home after all at which point im going to bed either way
so this queen is running out time to make the internet famous rock list or get thrown back out side
cletushowell
I think im loosing my mind is this rock eating the aluminum
is it like the missing element seiously the aluminum disolved left the coating and paint of the soda can but the more it dessolves it apppears the rock temperature increses and the rock appears to bubble a little more can the aluminum be condensing it to the rock like we eat food
i know the water and frequency condensed one to granite but how
can the aluminum go inside would it create the conductor between the iron
and offset oh im so confused useualy this means in about to solve it
oh the lid on the bucket contained the steam you can then see the lazer and the whole manetic feild so you need daves device in a steam room
with a wide enough lazer to see the entire movement of the water ion flow given the lazer is constant it should not effectivly change the feild unless you only do part of it you would be charging the steam it would go to the next polarity no its normal flow
cletushowell
Wooow that rocks doing sssome weird things
to that lazer its reflecting the lazer now in a v
not off the water its pulling it thru the water to the rock
and bending it back to itself then out the top
of the water not back to the thermoneter but back to ceiling
it will bounce off the hot water but not like the rock
its like you can see the atomic particles
like dust thru a window can that rock have stored enough energy through the day to literaly expand the nature of the atom
man im in pretty deep you know rocks radiate energy
i been pumping 120 volts to this one all day
its like bending light like a mirror ill try to film it this phone has not been couperating i think because the magnetism in that room
sparks
Quote from: Hope on September 03, 2010, 09:37:14 PM
Personal levitation feels like every cell in your body is vibrating and can get there by creating within a stream of acceptance.   Like allowing your judgement to refrain to "lovingly embrace" all thoughts till you somber off into a near dream state.  In my meditation experience I was seeing a large room with Hindu looking persons about, most were touching a 2o foot high orange glowing ball. When I touched the ball with the palms of my hands like they were doing my body vibrated all over and I floated 4-5 inches before my fear took over and I was back home and fell 4-5 inches back on the couch.   What is important about this experience was levitation wasn't what I thought it was, not a force lifting at the bottom.  It was all consuming yet I was in it and must say that when touching the glowing ball it was as if I was connected to another mind full of love and when I sensed the other mind fear overcame me and I fell.  It was as if we soul shared for a moment.  So fear separates us from this other joyous mind everyday unless we make the effort to reach it.  These things I share with you happened and I bear witness to it.   So within us is the ability to tap into greater things with out wires    self OU  LOL
      The problem being that a some point the people who do not have the ability to selfgenerate experience and rely on running all over the place to get their input put your body in a cage or a box because you dont quite act "normally".  You appear to be a danger to yourself and or others because you are not partaking in the usual animal delights of this world which you find mundane.  You are more of an observer of this world and less a part of it.  Weird but that is how it is coming down in my trip.  The other night I went out to feed the machine its daily caloric requirements and they had the fights on in the sports bar I happened into.  I watched the barkeeps go about there buisness and then watched the people watch the fighters.  The machines all getting workedup into a fervor over watching men beat themselves bloody for one machine need or another.   The images acting as some sort of testosterone secretion trigger.  I master my machine now it no longer rules me.  I noticed a few others that were outside the box.  We just shook our heads and shrugged our shoulders.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
sm0ky2
Cletus....
electricity is a catalyst....
2 aluminums bond with 3 oxygens to form an
DiAluminum-Trioxide
but to do this, one of the aluminums needs some electrons
so it steals it from a 3rd aluminum next to it.
this creates an aluminum ion, that bonds with the salt to create a FOAM.
and thus the aluminum is "eaten" in the process....
this is one of the few peculiar cases where a crystaline/metal compound is in the form of a foam.
i think this is important in the production of a necessary space-metal. we just need to figure out how to safely dissolve or compress the foam and let the crystals re-structure into a solid.
without breaking the ionic bond.
