a new kind of visible radiant energy?
Started by david lambright, August 17, 2010, 04:01:43 AM
do you like this topic?
yes, i will tell others about it
 no, it is BS
Rosemary Ainslie
Quote from: cletushowell on September 06, 2010, 11:33:37 AM
What i beleive is the weights and measures of life is the 8
the ballance the
56,000/9/6/3=1234567910
144,000/9/6/3= the missing8
so if you can send 1 8 back and forth
you dont need much energy at all its the perfect
ballance naturaly so you dont need to remove all the numbers
to make say a 2 go to a 3
you can just make all numbers go to 8
or from 8 how im not shure
Hi Cletus - I think you've made an error there.
try this 123.45679 x 3 x 6 x 9
Here are the increments.  370.370 37 then 2222.22222 then 19,999.99998
144 000/9/6/3 is indeed 888.88888888 - ?  That's amazing.
I think your posts are getting too long.  Rather do videos if you're up for it.
Kindest regards,
Rosie
cletushowell
A frame = a=aluminum
valintiness day the 14
silicon periodic table 14
the antigravity lifter aluminum foil
what does silicon and aluminum do?
cletushowell
I dont understand hope mine came to
20,000
but its not 20,000 its 200,000
144,000 +56,000
i think because its not including the 0
maybee you calculator doesnt go far enough
to the pattern
56,000/9/6/3=  345.679012345679
its continualy 123456790123456790
always no 8
cletushowell
I dont remember why i did this
maybee it will help someone i was filling in the parts
of the tesla death ray they cut out
i noticed from the sixth ave it was percentages
200000/3/6/.25=444444444/7
6,349.206349206349
13.5 /9/6/3 get rid of 1
.5 gets rid of 7
11.5 get rid of 2
Teen 43 three six  fifth 7
2.4 4.2
sorry its like i had my whole memory
wiped again in last week i have to stop answering the phone
how they do that is amazing i met a guy
who did the matrix three times they wiped his memory
each time if only i knew where that guy is
well this is my notes i think your 8
should stick to the bible code 12 and 12000
1.2 2.4 4.2 im really trying to understand the 12,000
then theres one level above that sorry my memory is gone its in revelations i think 24,000 and 24 sealed it doubles the energy of the frequency
speed 24,000 and 24 may not be correct numbers
there in bible though
cletushowell
a small success but none the less it finaly lifted ill be trying to improve it to acelarate the lift and the drops pretty fast the lift has a lot to do with the water temperature its in fact esier to lift in hot water then cold wich violates the laws dont ask me why the heat source should instanty rise but it doesnt untill it gets the gas producing a sufficient flow or the water
circling at a sufficeint flow or both not shure all I know it the stupid thing lifted it was actuay going a bit higer but hitting the side it wanted to go sideways im assuming flip not shure I changed containers but thats a whole different set of temperatures salt micture amp draws ect.
http://www.youtube.com/watch?v=9gJqxZab4BM
