a new kind of visible radiant energy?
Started by david lambright, August 17, 2010, 04:01:43 AM
0 Members and 27 Guests are viewing this topic.
do you like this topic?
yes, i will tell others about it
 no, it is BS
david lambright
hi everyone!....@smokey2!....i like you! will you be my friend?....seriously, the way you have got all this in perspective is so very cool!..the implications of these devices and their applications are something to think about!...anyway here are the specs....3/8" dia. aluminum tube bent into a circle, the cut ends meeting flush...two small holes drilled, one on each side of the cut ends...a coil of fine copper wire is put into the tube, the coil ends come out the small holes....dry iron oxide, Fe3O4, is now put into the tube, around the copper coil...i pack the oxide tightly in the tube, making certain there are no voids....after filling, i bend the tube to complete the loop, and tape the junction together....i now wrap i coil of about 20-30 turns of copper wire,20-22ga[i think] on the outside of the tube, to energize the device....when i energize it, i go + to - first, 2 or 3 times, then - to +, then its ready......i am still going to shoot a  how-to video, i have been a little busy and now i am going to be on Extreme Makeover, they are doing an episode here in salem, and by luck, i was at the right place/right time!...anyway it will be a little busy and hectic for a little while....i will still post...david
sparks
   Great job Cleuts.   Tesla had a thought experiment you can do.  Take a bottle and add some weights so it sinks to the bottom of a lake.  Add a tube to it so any gasses can come out the top.   Put a hole in the side of the tube so water entering has to go through a turbine that runs a generator that takes water and splits it into hydrogen and oxygen.  The hydrogen and oxygen flow from the bottle to the atmosphere through the tubing attached.  The bottle never fills up with water so the pressure differential driving the turbine never goes away.  A big plus in all this is that the hydrogen and oxygen can be detonated in an engine and recombine into water.  It will pull a vacuum on the cylinder not produce a pressure but it will make a piston move against a spring.  The hydrogen and oxygen recombination can occur at thousands of feet above the Earth.  The water from the recombination again flows over a turbine that helps pump out the cylinder because of any inefficiencies in the hydrolysis reaction.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
cletushowell
Well if that was a tesla idea it was a cletus mistake about 3
videos back it blew a hole in the side of the can a difference of energies
yes the water refills and continualy
evaporates a sr 72 blackbird has a bottom that leaks fuel
grandpa never said what the fuel was but wait till you see my ion
propulsion jet i just made now thats bad ass ill post it in a bit
trying to figure out if it shot the rock out or if the rock was in it
till i picked it up to tear it apart so people could see it
antways i rebuilt it twice i think you need
a aframe design around the rock so the continual exansion
and contraction is a bit more controlled its pretty cool
you never seen nothing like this
its my light bulb warp drive supercharged
my house is full of smoke give me a bit ill down load it
david lambright
hi everyone...@jesus...just wondering if you had anything interesting to post...@smokey ...excellent work!....looking forward to hearing more about it....this should be interesting....thanks for sharing your ideas with all of us...and smokey, your insight is priceless!....david
sparks
 @david
     Not trying to clutter your thread but I believe your device has alot to do with negative entrophy.  Or when heat application to a system makes its temperature drop.  You are adding energy to a system and increasing the ordering of the ferrite.  This produces your effect which I believe is electron cooling as they encounter the magnetic field of the device.  This gives rise to the light aberration round the device.  The photons generated by the electron cooling combining with the photons generated by the electron cooling that goes on in the corona or in a lightbulb or any other device where electrons slowdown.
Think Legacy
Spread the Love
