a new kind of visible radiant energy?
Started by david lambright, August 17, 2010, 04:01:43 AM
do you like this topic?
yes, i will tell others about it
 no, it is BS
david lambright
smokey2!.....OK you got past the spooky part....is your replication able to spin?...if so, take a piece of aluminum and hold it near the spinning device...you should feel a subtle push/pull effect on the metal....any metal really...remember what Ed said, "it likes to flow through metal easier than through air"......OK, so now a little more spooky action at a distance, so to speak...go to my utube channel and find "DO NOT TRY THIS!" video.....hold the metal near the image on the screen.....the energy that these devices emit, can be reproduced as easily as a video! my best results were with a mineral galena, a lead ore.....this really does work and still trips me out every time i do it....i better check and make sure that video is public....it was shot in UV.....interesting....also i have succeeded in making aluminum foil magnetic, enough so to stick to a magnet...jetijs over at EF has done the same thing with pop can thickness aluminum!....and heated the metal to near its MELTING point, way past any Curie point, and still retained its ability to stick to a magnet.....smokey2, thanks again for posting....if you like this, there is more......david....almost forgot, to make the magnetic aluminum, put it inbetween the keeper and the U of a PMH and energize it...keep it there a while 15 to 30 minutes should do and viola, there you have it!......david
Hope
My friend just came by a couple hours ago and we have (just like yours smokey) slit a pipe and made 48 sections    2inches long   but 1.3/8 inches dia rings  which we to will pry open if testing needs it.    Maybe tomorrow we will have a working model.   Thanks!    and have little fear of this device, Ed Leeds.. didn't die of cancer or grow horns or go blind.  But if you pump it up to HF  then the effect certainly may become a concern to quickly for me.  I also found copper and galvanized conduit clamps i want to make one with as a variance to check for shape and spacing.  We will get some 35mm film shots and scan them, in hope that  you can see this flow of fluid looking energy  (kind reminds me of when I had a magnifying glass and could see heat waves thru the lens while burning something).  Surely this type of shape is repeated many places in nature so we would already know if it is harmful it would seem.  On last thought,  smokey is bright and is correct in his cautions.   My friend and I will keep our models small for now till more is understood of this wavelength.
david lambright
thank all you replicators for your interest in this subject...as time goes on the results of your builds will show many more important effects...i chose to go open source so that this discovery will not be slowed down...there are modifications i can tell you to " boost" the wave form if any one wants to know, i will post how!....the oxide core devices work like a lens, with no glass or other medium, just air and space!....i hope to post a build on them soon..... david
ramset
David,
Very cool what you are doing here![Open source]
Have you ever put a piece of Gold close to your rig?
Chet
Thanks Grandma
nievesoliveras
Quote from: david lambright on August 13, 2010, 06:12:10 PM
jesus....OK, so give me a little while and i will send you a device!.....it does not weigh much, so shipping should not be a problem....thanks for your interest...david
@lambright
Hello first!
I would like to know if that offer is still valid.
Or if it was just ...
Jesus
