a new kind of visible radiant energy?
Started by david lambright, August 17, 2010, 04:01:43 AM
do you like this topic?
yes, i will tell others about it
 no, it is BS
cletushowell
How does a magnet made from daves device
react to a standard iron magnet made from electricity
seems like there opposites to me
one would be two seasons and one would be the other two
and so you would have four poles
of magnetism the four seasons
daves should be fall and winter and a regular magnet should be
spring and summer the way you should
be able to test would be four magnets
two if daves and two regular magnets
put them in a circle of four then flop between
daves two and the two standard
magnets fall and summer
with winter and spring
that should line summer up with winter
and spring with fall and none should touch
ya i think i just did the imposible in my head again
what that does i dont know you cant flip the other way it has to put summer and winter together to prove daves magnets are winter and fall oposites of regular magnets
and
cletushowell
Hope you asked about the helix
theres only two helix
then the star of david
david Lamberts device is essentialy the star
its the center of the wrong rodin coil
what it would wind around its creating daves magnetism
and dave creating the coil there almost exact oposites
its really facinating to me to see this war
of math and energy like tesla and edison
all over again its between oil and electric
trying to understand coils and magnetism
relating geometry and numbers shapes and power
religion and myth frequencies and
numbers the only thing not debated is polarity
and I brought that up polarity is not
+- even odd are 1 and 2 energy
not -1 +1 that seems like the biggest
mistake to me but it doesnt change anything I guess
except the way people veiw it Im kinda trying to understand
spark quenching the gap and pressure bulbs
then i think i can build this moray valve better
i wish i had silicon maybee later i get some money
id like to make that rock under the revolving door
theres spray silicon at hardware store is that the right stuff
david lambright
hi everyone!...what is litz wire and where do i get some?...also, i am trying to locate some tubing made of different metals....zinc, lead, bismuth, titanium...i have a bit of mercury, 4 pounds, if i froze it i could make a torus...too complicated....or what if i am going about this "wrong".....i think i might try putting metals with the oxide, in small amounts...i took a bismuth crystal, bought from OMSI, and filed it to obtain some small pieces, mixed it with the Fe3O4 i already have, and filled& packed a 4 or 5 inch piece of clear vinyl tubing...using a little bigger tube, i cut a 1/2" long  section to serve as a coupling...i put the ends together, making sure the tube was filled with the mixture....20-30 wraps of transformer wire, thin copper, and energized like a PMH.......this works but the best lens effect is still with the ferro fluid core device....another one i made from 1/2" corrugated SS tubing, 3" dia. that seems to feel almost like a centrifuge?[steven mark?]...i have to test that more before i say for sure...david
cletushowell
Sparks can you or someone explain this
if i can tune the wireless trasmission
like this i can light the bulb without changings the gas
or understanding it right shouldnt i be able to
do this i think this is my answer to why i can turn motors but not light the incandescent
please if you understand it email me
ch@helpuflip.com
Check out this video on YouTube:
http://www.youtube.com/watch?v=ZYgFuUl9_Vs&feature=youtube_gdata_player
Sent from my iPhone
Rosemary Ainslie
Hi Cletus.  That's a neat link.  Thanks for that.
Regards,
Rosie
