a new kind of visible radiant energy?
Started by david lambright, August 17, 2010, 04:01:43 AM
do you like this topic?
yes, i will tell others about it
 no, it is BS
cletushowell
I seee a link why did our bee population drop in half why is goverment really spraying chemtrails to make bees
possibly
Check out this video on YouTube:
http://www.youtube.com/watch?v=itjqNelz5WU&feature=youtube_gdata_player
Sent from my iPhone
sm0ky2
update on my new build
i got all 12 pieces of the inner ring cut, filed, sanded
and cleaned up.
need to decide how far to open the gaps now....
[The magnetron ring is not part of the build, im just using it to hold all the pieces, and it makes this kewl Searl Effect]
cletushowell
Smoky I met with my brother I had him look over the math and the concepts he said i should finished the star
im going work on that tomaroe
he said the cut when paralled equals offsets the
5 cursed myan days and the 6
i hope you watched the videos
i posted and i figured out from
another arthur young the demntiond if the 8
are like this 878
the center not 87 so the cener is held together by 7
there is no 7 theres two 8
88= 16 16 =7
so the 7 is the perfect number the day god rested
its a rest or bond not shure how to explain
the 7 its created by the third dementions
on a line 8 on one side 8 on the other
7 is the middle
sorry i got a mrsa infection again
on my scalp stupid drs it might be in my brain
better say some prayers goverment at there best again
dam fucking me up fast
oh read my antigravity post its the bee
the stinger is the antenna radiation
antigravity cant wait to test i put some
sugar out waiting for bees to come back
oh and my brother helped me understand exactly how to bond that
silicon to alumium email me again if you have a lab or rose ill tell you before these fuckers kill me i did teslas black box sent it to lid
hope he understood i need a inductor if anyone has a extra
how much are those i read about a one wire inductor but havent seen it that would tune the 369188
if i could put the inductor in the 1 loop not shure how those work yet
why didnt someone explain that to me?
Seems like it would tune the frequency to anything
not just earth cant wait i got some things I plan to shake a bit
oh how fun when im done learning all this stuff
if i live maybee I solved enough so Gods Going to tske me home I hope
that be nice
dllabarre
Quote from: cletushowell on September 09, 2010, 12:22:50 AM
that be nice
HE will take you home when your work is done here on Earth.  :)
Don't stop your work here.
DonL
cletushowell
So the black holle is the 7
10.   2 7 all the verses of moving the mountain
and mustar seed
10 1 loop two polarities
of 8
think of it like hutchesion
when 8 and 8 are on both sides
7 is in the middle the 7 is free floating did you see the first video
how the 8 moves around thats the whole concept but
split the 88 one below one above tune the frequency
like hutchesion whala antigravity
now just need some experiance and some exquipment
i think you still need daves device
to have the negative introphy on one 8  you know why
when you warp you can only go as long as your power source can hold you like hutchesion pushing things with the crystal
when its auto perfect pulled and pushed
its no longer streched the energy specific gravity stay the same
inside thats my theory and in sticking to it eds the only one to warp things in one peice and leave them the only way you can leave them is if the negative introphy is controlled so how does that silicon aluminum do that on the door
is there a rod into that silicon that transfers the 8
to the top that rock like if you put a pipe in a circle magnet
it would magnetise would it change gravity around the pipe
well it must if it becones a magnet and holds something to it
now what if you had two pipes on on inside and one outside the magnet and
a magnet top and bottom which way could you pull the iron
up down side to side seems like thats antigravity to me
four electromagnets could float about anything
inside a tube just tune them but if you had 6 on the side
one on bottom one on top you could repel pull turn and rotate
yep thats cool well good night all
