a new kind of visible radiant energy?
Started by david lambright, August 17, 2010, 04:01:43 AM
0 Members and 27 Guests are viewing this topic.
do you like this topic?
yes, i will tell others about it
 no, it is BS
cletushowell
Don you got a key those that got a key to string theory look close at the ceter box you see the pryramids from every angle ok that box is impossible to implode you know why the strength is equaly distributed
back from each side fllow the triangles rememer the middle dot is the back of the bottom and front of the top of the box
so heres what i did hope this helps explain teslas black box
the myth busters proved you can oscilate a swing all the way around but they missed the phsyics the reason they did it was the chain was switced to a pole so when you cross half way the energy does not fold but help in
place by the rod where the chain would go
that allows the swing to maintain momentum
but they missed the best part if you
changed the rod above you head when your on the swing to a fiberglass
bending pole then when you cross half way the solid rod stores
the energy to the fiberglass now when you get going all the way around
your bouncing the fiberglass rod but tesla tuned the light bulbs with the inductor to bounce the fiberglass rods with frequency and spin the swing
thats the key to the physics of what tesla did
im going need help with the electronics but i got this one
Rosemary Ainslie
Dear Jet,
In the hopes that you subscribe to this thread - I wonder if I could ask you to read your pm's and get back to me.  I can be reached at ainslie@mweb.co.za or on these message systems.  Whichever is easier.
Kindest regards,
Rosemary
Guys sorry for the intrusion.  I'm having difficulty reaching our member here.
Rosemary Ainslie
Quote from: sm0ky2 on September 08, 2010, 11:24:42 PM
update on my new build
i got all 12 pieces of the inner ring cut, filed, sanded
and cleaned up.
need to decide how far to open the gaps now....
[The magnetron ring is not part of the build, im just using it to hold all the pieces, and it makes this kewl Searl Effect]
  ;D Sm0ky - that rig of yours is SMOKING.  LOL.  VERY NICE INDEED.
Kindest regards,
Rosemary
cletushowell
I did the 888888 found the matrix for this code was on tthe coral
castle video dont know what the code is for i dont have a book
it looks like three frequencies
anuways the code i got was 71296105195
so I have the matrix for that if anyones knows what it does
ch@helpuflip.com
cletushowell
Woow ok guys got a message from God I guess
some one sent it to my phone as a hacked
text but i tested it was not the sender
Once the circle is spinning and after it bounces back and forth lIke the tesla coil with magnet in the middle which is the first step then it will spin  in a circle  and chase itself indefinitely until it is broken but it can easily be broken I gunk that's why they wouldn't let the coral castle pAtent be given because when the magnets are in a circle chasing themselves the way to stop it only if it is unpowered is with a single magnet on the outside of the circle in any magnetic force following itself would be a single magnetic force either of positive or negative but not both however I am unsure if a sudden stop would be possible or even wise which is why tesla's box was shot only other way to stop it is destruction of itself just thought you should know and also instead of being harmonically stable with the most usable power output if you keep it constantly offset where the sonic harmonics would fight themselves equally you might need two in the box for this the would constantly be at equal odds which would cause the harmonic balance to offset gravity read this carefully I believe this may be the difference
so here a bunch of info
