a new kind of visible radiant energy?
Started by david lambright, August 17, 2010, 04:01:43 AM
do you like this topic?
yes, i will tell others about it
 no, it is BS
sparks
  I did this head trip once.  Suppose you develop ominpotence and dont know the first thing about being in pieces.  So you say Ill put little piece of me over there.  Now there is no there at this point you have to make there.  So you conjure up a point.  Just this thought of a single point.  Now you do it and you look at it for awhile and its pretty boring.  Its just a point scource.  So you go about working on bunches of points and realize all these points are still stuck together in that first point.  So you say think well at least I got something I can see that is different.  And at least it is and there is a there.  Let me imagine up different theres.  Different theres start springing up everywhere.  Hmmm looks pretty much like it was before everything is still all the same it just there everywheres.  Well what if I take these theres and make them into bigger and smaller theres.  This there wont be the same as that there.  They will be different theres.  So you make one there over or under the other theres.  Ah now the theres are relative to each other.
Lets see from the first there all sorts of theres start to take form.  If I take a there I can start creating dimension all relative to my first there.  I can have as many as I want because well I'm in charge of me so Ill create a bunch of theres that are all duplications of the first point scource but are just a little different.  Just different enough so a line appears.  The line and a circle are the same it is just a path through theres.  Well thats cool.  I got a line and a circle but hmm they are still looking alot like my first there but at least a line and a circle are coming into view.  Well what if I take a different tirp between the theres.  First I go and observe these theres and then I observe those theres.  Direction thats what I can do I can direct my consiousness through different paths.  I can go along the line this way and then go back to where I started looking and then start to observe those theres.  I have a vector.  I have a line and now I have a vector.  Now lets see if I go this way then that way then this way then that way I can have changing vectors.  This is cool because every time I change vector I can locate see a difference between that there and other theres.  Its like I can stop seeing all the lines and circles as being the same and when I take a different consious path I rest on a definite there.  This thing I call resting will be named zero.    It will be unlike any there it is the rest position where my consious will project from.  From this there I will choose my vector.  What will be different about this there is that it will be called where where give birth to a new vector.  Hmm now I can either be resting or creating vectors.  Ah that makes it different between when I am resting and when I am vectoring.  So what should I call this vectoring game.  I will call it motion.  Hmm at rest on the zero there and moving in a vector until I rest on another zero and change diretion of my attention again.  Those other theres I move through while in motion should have names.  They are just as good as the first there so I shall name them as I go along.  Hmm this will be alot of names.  Perhaps I will observe them and name them according to how they differ from the rest point where I change my direction of consciousness.  They will be named time.  These theres will be named time.  As I direct my consiousness from observance of vectors and resting theres in between will be called time.  As I move my consiousness between resting and observing I will move through time theres.  They will all have the ability to be zero points as I will be able to rest on them at will.  Hmmm.  I have motion as I vector between zeropoints I now can direct my consiousness from any zero point.  Along infinite vectors emanating from the zeropoint I rest on.  I will rest in the zeropoint and go forward into motion of consiousness along lines of motion and rest at the point I call zero.  Hmmm.  I can move in consiousness from any zeropoint of rest into motion along vectors until I desire to rest.  Then I will rest at zeropoint and change consious paths as I move/  I will radiate my consiousness from zero point and return to zero point to radiate my consiousness again.  In so doing I will name all that I become consious of time.  There will be consiousness of time  as I move my consiousness along vectors emanating from the zero point.  .  I will call this movement of consiousness through time theres from the zeropoint to when I rest on the zero point an interval.  Time consiousness along vectors of motion from zero point to all theres will create finite from infinite.  I will create time intervals.  I will create frequency.  I will be in infinite forms of consciousness and will create all that is.  I will time.  I will seperation of consiousness to experience me in all my infinite forms.  Some resting in the zeropoint some radiating through time but always of my consiousness.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
cletushowell
Maybey two steps forward
one steps back
jesus dies32
16= 7 but 7is7and8
12 +8=20
12 is32 but you need those cursed days
but this is wierd jesus dies and rose again
in 3 right sorry mightb wrong memory prob
3 is equal to 3000
the 369 1 day is equal to a thousand
so if we remove 3 days 2 can come out the center
the 8 im not shure yet typing to rememer thats puts us two stepd forward 1 step back would one circle then the helix should release 1
and hit the other side release those two
hit the oposite the helix where it came from
so the egg  is 3 1.2 but 12 the sperm is 78
make a whole 2 halfs the body 144,000,56,000
im curiousif anyones ever done ratio of
insides the egg the fluid to yoke when the sun
never rises and i sleep eternaly then I will enjoy life
every day I awake is like being born back to sin
a miserable hell while im at it remind to to tell obama im our
debate that he can refer to me by my
number the same as this gov always has
the state ca by my drivers number
and id like to refer to him by his
if he has one.
sm0ky2
@ Cletus
theres no set ratio of an egg.
Yolks vary greatly within a given species. It has to do with rate of development, and the health of the parent.
even with the same parents, the animals may hatch "more grown" than the other. Even an unfertilized egg has a different yolk to albumen ratio than another egg sitting next to it.
The Egg starts out as a single cell, encoded with the genetic acid sequence of its parent. the cell divides many times, and forms into the "shell" and begins forming a membrane inside.
as it expands the albumen fluid cells begin forming and dividing.
then a single cell forms in the middle. The Yolk.
the yolk cell divides and multiplies with the egg as it grows.
the yolk too forms a membrane around itself.
which it uses to eat the albumen (fluid) as it grows.
(eats more once it becomes fertilized)
Ratios can vary from egg to egg,
generally the inner mass is between 1/3 to 2/3's yolk
cletushowell
Theeee middle is the stem cell
the pattern im not done with
8 does exits its 1 in the center
wich is 16=7 can
in middle
so two 8 make 7
1-2-4 8splits to two 4 fils in 4 of the six
on each side that leave 4 in the middle
those now can leave the middle and fill
2 on each of the empty holes on both sides the original
six cans thats about as far as i got
144 is the middle looks like splits in
8s to me its pretty hard
cletushowell
144 1doubles -2 doubles to 4
144=18
3 rings of six when you remove the center
fuck all this which came first the chicken or the
egg god made the firsf day a 7
7x6 42 fucker never worked a day
