a new kind of visible radiant energy?
Started by david lambright, August 17, 2010, 04:01:43 AM
do you like this topic?
yes, i will tell others about it
 no, it is BS
cletushowell
Hope remember what i said if a truck goes up a hill and you drop the hill
just before the top you then are taking tge energy
from the truck going down the hill biy also the energy holding the truck up
before it continues to jump the gap of the hill
i just removed i think this circuit or drawing does that
and if the weight of the truck is the electricity going thru the wire
the hill is the resistance of the wire when the resistance is removed
the trucks velocity still jumps the Gap the spark gap now how do you add
the force holding the truck up to the top again
well hope you said jump peak to peak ill examin tgis drawing
more but i see the double oscilation of the energy from the top of the hill being remove before the truck still takes is normal path to the ground but if you convert the energy holding tge hill up from behind
you to infront of you then you can move mountains
by manipulating the wave
cletushowell
@alvaro cheers who is Gurdieff
this is amazing work
lets start at the top
9
81=9
72=9
63=9
54=9
top right
91=10
82=10
73=10
64=10
10splits 555
right top
12=twelve
93=12
84=12
75=12
12splits the666
Right side
23=5
14=5
95=14=5
86=14
14splits to 777
bottom right
34=7
52=7
61=7
79=16=7
16splits the 888
bottom is reverse of the top
wait no the 9 does split down
56=11
43=7
11+7=18
so 18 splits the 9 goes to middle of two 9
instid of around it what is this a antigravity
formula
anuways i dont know what it does but ill continue
54=9
63=9
72=9
81=9
but 87 is 15 +12 =3+15=18 999
bottom left
65 =11
74=11
83=11
92=11
11 splits the1 111
left 76=13
85=13
94=13
13=4
4 splots the 2 222
top left
87=15
96=15
15 =6
6splits 333
id say last but I dont think there is a last because
it goes wider then two
but 89 =17
17=8
62=8
53=8
8split 444
so what does it do makes the numbers it splits invisible
but beings 9 splits the 65 and 43
it must make the whole thing invisible
very cool ill search this gurdjieff guy
see what I can find
cletushowell
You know some times i think i give my work
credit to others like this circuit could just be
a led circuit i have no clue but then mabee I see
more in it then most or add to it ill searxh this guy and see
what I can find he probly knows more about this then i could ever dream
who knows
tagor
Quote from: ALVARO_CS on September 11, 2010, 04:41:35 AM
Sorry for my poor english, (spanish is my first lenguage) I don´t now how to translate the word "ENEAGRAMA"
Observe the absence of the 1, 3 and 6
cheers
Alvaro
EDIT: I apologize, I meant the absence of 3-6-9 from the circuit
"ENEAGRAMA" is enneagram
cletushowell
That has really got me thinking about
is this pattern the key to the force
itself 9 does not jist split 18
all numbers split each other and
for example 3 is the middle between
7and8 because 7 and 8 make 15 which is 6
six splits to three three
which puts the 3 directly across in the middle
three 3 three
but if you go reverse it goes
87 17= 15 69=15 15 =6 24=6
6 then splits three
The exact oposite on the outside
but the the exact same wow
this is insane what can it all do
this is like the biggest mathmatical
discovery ever its like impossible to explode or implode
its the matrix of the invisible and
full numbers a joining of everything
why he left the lines open between
its insane the bottom is
65 43 =18 look at the top 18
what is 18? 9 its so simple
23 =5 86 across=14=5 14 splits the 7
can anyone find a error in this anywhere
i think its bullit proof
