a new kind of visible radiant energy?
Started by david lambright, August 17, 2010, 04:01:43 AM
do you like this topic?
yes, i will tell others about it
 no, it is BS
cletushowell
Because  9
64 =11.     43=7
11+7=18
which splits the 9 but where does the nine
actualy land
11-7=4
11 is2
7-2= 5
im trying to do the rest the dementions
as well
cletushowell
From what i can tell the math is incredibly
perfect but the structure in which it lies
is wrong there no helix or repeating parterns or
even design some how i have to incorporate it into
the string theory design to have the gaps
between the triangles filled perfect with numbers
how its so perfect is amazing it goes much farther then
1-9 it goes probly farther the i can do
i should make some videos but i dont know
if thats best as the numbers in wrong structure would give the wrong result
im a little baffled by the complexity of both
and how they for example if 1-8
=72 its not a circle but it would work in the string theory
if the 1 and 8 fliped over the 9
to create its own triangle equal to the 72
i probly need help with it someone who can add the waves
the numbers are pulled between as they travel
say between 65 is 11 as that line goes to 1
its pulled by 74 still 11 but over by 1 stretching the line
how do you calculate for this im not shure
cletushowell
Maybee this stretch is the curvature of
space time if the time from 11 to 1 is changed relative to the number
it passes through it would speed up and slow down
depending on the stretch but still land in the same spot
samd ultimate time but what that time would be
would not be determined by the strect but the amount of
energy 7 and 4 have a magnetic filed stronger
the 83 then it woukd slow time and speed up
as you travel thru the field the same as passing a magnet
it pulls you in can hold you or push you
the strength can determine how long your held pulled or pushed
so maybee we now have the formula for the space time field
i just have to put it together somehow
sparks
  An equilateral triangle can be rotated to form a circle.  You get a star of david from a 180 degree rotation.   I have seen this geometry thousands of times in various forms of symbolism.  Unfortunately triginometry and calculus and all the rest of modern mathmatics is based on the rotation of an equilateral triangle creating a circle.  If you look at the below sphere inside a pyramid that the pyramid contains the sphere which contains the equilateral triangel that defines the sphere.  You can not contain a pyramid within a sphere.  You have to create two pyramids containing two spheres whose poles can then be rotated to define a circle which then is contained within a larger pyramid with its twin then able to be rotated and define a circle on into infinitety and in the direction into a single point.  This is the life symbol.  This is how things grow.  The equilateral triange divided in two and the pathagoream  theorum and all the mathmatics based on this theory will never explain the life force.  The expansion of consiousness because it is unable to be relative to anything in a state of flux.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
cletushowell
Its a math system of faith
Faith is believing that what you don't see evidence for exist
its a matrix of faith the things you dont
see its really cool I wish i understood it
all I think im going to call it faith based
mathmatics in which any number you chose
can be another number through faith
between a 65 is a 5.5 a 11 but
wait 11 is 2 and 55 is 10 but 10 is 82
but 11 is a 6.5 to get a invisible 6.5 you need to split
a 76 because 76 is 13 half 13 is 6.5
so 6.5 is a 76 ill do one circle
bless you with the pattern
and leave draw these in a circle for now
till im done
9,5,10,6,2,7,3,8,4,9,5,10,6,11,7,12,8,4
there you go so lets pick 9 in the center
you can do any number but because were
flat well do 9 splits 45,=9 108=18=9
36=9 117=18=9 72=9 12,6=9 810=9
and last 54 =9 being your last number
i wont do all 4 but just pick 4
98=17 =8= 444 go all the way your
back to 89 maybee ill do a video
it probly needs about a weeks worth
to even try to explain faith based math
system
