a new kind of visible radiant energy?
Started by david lambright, August 17, 2010, 04:01:43 AM
do you like this topic?
yes, i will tell others about it
 no, it is BS
truthbeknown
Quote from: cletushowell on September 12, 2010, 11:30:19 PM
Its a math system of faith
Faith is believing that what you don't see evidence for exist
its a matrix of faith the things you dont
see its really cool I wish i understood it
all I think im going to call it faith based
mathmatics in which any number you chose
can be another number through faith
between a 65 is a 5.5 a 11 but
wait 11 is 2 and 55 is 10 but 10 is 82
but 11 is a 6.5 to get a invisible 6.5 you need to split
a 76 because 76 is 13 half 13 is 6.5
so 6.5 is a 76 ill do one circle
bless you with the pattern
and leave draw these in a circle for now
till im done
9,5,10,6,2,7,3,8,4,9,5,10,6,11,7,12,8,4
there you go so lets pick 9 in the center
you can do any number but because were
flat well do 9 splits 45,=9 108=18=9
36=9 117=18=9 72=9 12,6=9 810=9
and last 54 =9 being your last number
i wont do all 4 but just pick 4
98=17 =8= 444 go all the way your
back to 89 maybee ill do a video
it probly needs about a weeks worth
to even try to explain faith based math
system
All the comments are interesting BUT haven't the past couple of days or more strayed away from Davids original topic for discussion? Just noticing.
J.  ;)
sparks
   Below I drew a line at 12 oclock on the circle.  I then trunkated the resulting pyramid.  This leaves the parent pyramid intact containing the original sphere.  Then I raised the newborn or seed pyramid which is an exact duplicate of the parent.  This seed pyramid can only grow and enlarge into the size of the parent if it meets a second seed pyramid.  Then it can join rotate define a new sphere and expand until it becomes the same size as the parent pyramids.  I can only truncate the pyramid at the zenith of the spheree and get a scale model of the parent pyramid.  For some reason this was done on a dollar bill and an eye stuck in it.  I think the eye represents the ability to observe or be consious.  This flying pyramid top came from the parent pyramid below.  In it we see a large sphere encompassed.  The consiousness or life flowing from the lower to the upper.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
cletushowell
It. Would apear yes the original
topic is so complex and unknow
its literaly forced a whole new set of
math to define it how a radiant energy is made
from a Gap that is the math in which
im working i know it very complicated
but the edges of the pipe make the
gap so the gap is in esssnce faith
a force in which you cannot see but we know its there
so how do you calculate the radiant force
or the size if the gap now thats where
stems cells can change to any number
but radiant numbers the invisible force
can be any numbers as well but when you understand
that pattern of the radiant numbers then you can create
the same radiant from a series of numbers
you can essentialy build the life arround the stem cell
its way to complicated sorry its probly is a distraction
ill try to limit it to videos. But im not very smart
and help from rose and sparks that know more how to use the
math is probly the only way it can be done I really dont know
how to do it some how I get the answers with no problem
and have to make the problem to the answers
I work in reverse like tesla I guess I see the finished product
first then try to figure out the pieces to
the puzzle the gov took my brothers
phone and computer so I cant get help
finishing this its called 4th demention but
I think i took it more I did a lot of calculations
so much i think its now above me or needs a
second person to push the envelope to create the problems
for me to solve I did the outer ring sparks you can fill in tje string
theory with it but im really strugling on the
star the decimals seeing everything in
all dementions is very hard i think it has to be broke down
so its easier understood where the radiat energy is
like the radiant energy between 7,8
is 15,6,7.5,7.5, 12,3 its more but ill
stop the radiant field is made up like tge stem
cell it can be any numbers so do things like
magnetise aluminum possible heal
people who knows what all it can do
its a invisible field that can change
numbers fluxuate i guess I dont know how to explain
it. Just trying to do the math for the field
so its understood ya testing can probly
do a lot but if the matrix is done right for it then you could just build it
to make the field you desired thats what im trying to do
its not easy maybee i cant do it. Im trying
cletushowell
The space between pyramisa i hit to
when the 45 flip over to the 54
i dont understand how the 45 and 54
can connect yet its the 5 cursed days
and the 4 is the box the 5th is the peak
its the interlock but i dont see it yet
sorry i cant read all your message tge picture
blocks it on my phone im stuck in bed
fighting this mrsa
twinbeard
the astroturfing is getting pretty heavy in here.
