a new kind of visible radiant energy?
Started by david lambright, August 17, 2010, 04:01:43 AM
do you like this topic?
yes, i will tell others about it
 no, it is BS
void109
Unfortunately my camera is a canon so I dont have infrared capabilities.  I'll try some low light environments.
david lambright
hi...try this...get a LED flashlight and hold the OC device by the wires and move the flashlight rapidly back and forth while shining the beam on the OC device.....i feel the light pushing the device...very subtle...5 others also felt this......interesting....   http://www.youtube.com/watch?v=C7ieULmQO5U   ....david
void109
Quote from: david lambright on September 18, 2010, 08:16:32 PM
I cant help but wonder if what we're seeing in the footage isnt just a lighting artifact of the material and the lens.  In your latest video from about 3:04 and beyond, I see the same type of anomalies to the right of the object, not within the inner circle.
I did stuff a large fisher price donut full of oxide and juiced it.  I still see or feel no phenomenon, however there was one curiosity (which I dont know that its noteworthy), when I move my compass around it post charge, north points to the coil at two different positions  on the donut, lets say the first is at 0 degrees.  Then the second northward position is at 120 degrees.  I was hoping to see another at 240 but there isnt.  So moving the compass around, its north at 0, south at 60, north at 120, south at 240 and north again at 0.
I pulsed the coil in many locations, meaning, I'd move it incrementally around the donut and blip it with current.  The positions would rarely deviate and if they did, it was always under 5-10 degrees of deviation and they would deviate by the same amount, so it was always 120 degrees between the two north positions.  At one point I banged the donut around (since its stuffed with iron oxide powder) hoping to settle any miscreant pockets of air, and I flexed it severely.  This resulted in the two points being shifted by around 5 degrees.  It would eventually settle back to the original positions ( I had marked these as soon as I noted them).
Dont know if its interesting, but that's all I've seen so far.  I didnt have an LED flashlight, I tried playing with a laser pointer to see any effect.  I also hung it in various positions and rotated it.  Even placed it flat on a retired orbo platform I was toying with and spun it up looking for anything interesting to emerge.  No dice yet.  I'll sit on it for awhile and try something new when I have an epiphany. :)
cletushowell
Ok i just kkinda understood a lot today basicaly
I found zero point energy its between
resitance and vacume and resistance
or vice versa
so I did a lot on the moray cell tesla black box
but also I now understand coral castle
ok ground is a vacume= gravity
the rock is a vacume
the air is resistence
the air resistence is most at night
the moisture on the rock negates the
amount of vacume the rock has
by neutralizing the energy radiation
also the salt does the same
so now there has to be resistence
put between the rock to equal the air
this has to be a reverse generator
ac current is a vacume we need a ressitor
a pressure like in the incandescent bulb is a
resistor so some how that generator makes reverse of ac a
open loop generator some how like
maybee because the cut is not a closed loop
it generates negative energy that when equal to the rock will lift it hes ballancing the vacume of the rock between the resistance of air
and resistance he makes with the generator
anyways i think your stuck on a metal
compass i think you might find your missing poles using aluminum
just a thought aluminum and steel are oposites
aluminum does not take -ions i think
anyways - or + its opposite of salt Iron
oh i got it a aluminum wire to the
water box the generator can
turn the water to negative with a aluminum wire
he should be able to lift the rock
dam I did a lot in one day.
cletushowell
@hope
water is a vacume huh thats got me
on the rock the rock is vacume do two - = positive
have to test i guess huh?
Well anyways flourescent is a
vacume so the ac is a vacume
and ground is a vacume
so the only way to light the flourescent
is a ballast wich must be resistor
so if water is a vacume a ballast should make more hydrogen
then you ever seen. Ill search ballast to see how the hell it makes
resistance so with a aluminum wire and a ballast should
give you resistence to levitate the rock
I think ed was threatened by goverment to infact
his pattent were denied by einstien the German spi for his dad
tesla manhaten project was from his manhatten earth quake
the nukes a hydrogen bomb
the cities were leveled with scalar waves
edison didnt invent the dc or light bulb
teslas first pattent 1985 1930 was when he was said to work for edison
go figure how they fuck all history up.
So 911 scalar waves tuned it triangulate
crash the planes like droping hydrogen
bomb level the buildings a big scandal
oh i forgot crank up the bass 1 billion watts
then level it
