a new kind of visible radiant energy?
Started by david lambright, August 17, 2010, 04:01:43 AM
do you like this topic?
yes, i will tell others about it
 no, it is BS
neptune
@David Lambright . Many thanks for that info . Can I just say that the facts in my last post are as downloaded from the internet . I cannot confirm them , especially the one about Government Classification , and you must do your own research Also anyone using Dye cells or aura goggles is reminded to observe all safety precautions .
neptune
Aura Goggles on Ebay at about £41 . No idea if they work or not .
neptune
Just keeping the topic alive . I dont normally post replies with no substance , but this is no more SPAM than the Golf tips...
david lambright
....i was using a small piece of calcite and what i feel now is similar to 2 opposing magnets...holding the calcite about 1/4" above the HDPE center...when i feel the push, i keep it in the same spot and the effect starts to grow, it pushes back harder....i cannot tell if it is being pushed or like Ed said about it being magnets that control muscle contraction...in any case it is a very strange sensation....the calcite splits light into 2 streams..Ed did say the streams had to be divided...and then run them against each other...that makes sense with what i have felt...with a convex mirror at the plane, i feel a pushing .but it is so small... just a part of this energy can be reflected...just as X and other waves penetrate materials, i believe this energy will do also..if the streams can be separated using calcite that would be interesting... to separate the N and S into streams, the PMH is used....gravity and levity are like a vortex to a point to vortex...temperature is the zero point ..the PMH is also at that point. ..lets say N = levity, S = gravity...L and G can only go one way so reversal of the polarity at the point and changing the dominant stream of magnetic current, with the PMH...is the how....when a PMH is energized ,an orbit starts...ring the bell a second time and dominance is reversed....if the dominant stream has been reversed properly, the PMH acts as the zero point ...now if the PMH is spun, the gravity does what it knows and goes to the plane but now its carrying the N ...and, levity at the pole and S...any pull of G + N results in a S + L push...these streams would prefer to travel in the metal....so put a S magnet at the plane, just like in the photo of Ed, and spin the device so gravity and the N at the plane...levity and S at the pole that can now be collected at the wire above the device, flowing upward [like heat convection] into the mass above...as the magnet and the rotor pull N and gravity, S and levity flow up the wire , from above the generator, to be used at the quarry..the S being attracted to the north, flows into the stone bringing L with it...i believe that weight, as we experience here on earth, is due to the gravity to levity ratio...this can be changed .every thing has a zero point...at the quarry, the wire that comes from the mass above the pole is copper...steel, i believe was used to cut the stone, but i think the wire was connected to the flat bar he used at the quarry...i also think that because the S attracts N. the flow of L+ S from the tool softened the stone making it easier to work?.......i am pretty sure that this is how it was done..... i have found that the PMH is multi functional and ...i want to prove that this, how Ed .built his castle....david
