a new kind of visible radiant energy?
Started by david lambright, August 17, 2010, 04:01:43 AM
do you like this topic?
yes, i will tell others about it
 no, it is BS
david lambright
more theory.....magnetism is not quite equal...one pole is stronger than the other.....pulsing a PMH twice changes the polarity of the dominant stream...lets say Earth has a dominant N...in my experiments with a toroidal PMH show that polarity is connected to thermal convection...a PMH with a dominant S has thermal convective flows reversed from what is natural on Earths surface...these flows are visible with the naked eye as they dissapate back into the field, like a mirage...the flow has been seen and recorded by many people...this flow of convective force is not connected to heat....just like a magnet, this flow has polarity but its polarity can be reversed...unlike poles attract....so the PMHs dominant S is attracted to Earths N...if you want, try this....energize a PMH two times...take a piece of calcite and lightly hold it near the PMH....you will find that there are places on the ring [circular PMH] that will repel the calcitce crystal...try this cheap and easy expirement for yourself.. .in a PMH, the force flows in the center of the material...we know that this force is magnetic in its nature, holding the keeper on PMH and lighting a bulb shows us this...this ENERGY,being a bi-directional flow.and being magnetic in nature is attracted to the poles of a magnet and since it likes to flow in metal can be coaxed to flow in a wire...everyone has seen the photo of Ed with his hand on his "rotor" right?...why is there the mass of metal ABOVE his device?...this metal mass had to be above the rotor for this polarized flow to accumulate into....a wire from  this over to his quarry ...this half of the flow  being polarized S but now it carries upward  convection, is attracted to Earths N like an upside-down siphon...spinning the rotor  started the flow which would continue to flow from the S wire as long as the siphon didnt break...this flow could then be used to fill the stones with S polarized, upward convective force [levity]....and the same way heat is absorbed, a stone could be filled to its buoyancy point and moved...as the stone "cooled" its weight comes back...this flow of energy is distinct ....it can flow forever...we know that super cooled matter does this, by cooling them to their reverse buoyancy point.....as they warm back up their weight returns....Ed did this exact thing, using the earths natural fields....this is my theory these conclusions were arrived at through experimentation and rediscovery! thanks.......david
neptune
@David Lambright . Hi David and thanks for the info you keep giving us . First a couple of questions . In the experiment where the Calcite crystal is repelled you refer to a circular PMH . With the exception of Leedskalnins horseshoe shaped PMH , all PMH are circular . Did you mean the iron hoop with a gap , the oxide core device , or the device with the pipe segments ? Or does it work with any and all of these .Please give us specific information . You say that the Cristal is repelled from certain points on the ring . How do these points relate to poles on the ring detected by a magnetic compass ?
        The repulsion of the crystal . Does this happen only when the crystal is hand held ? suspend the crystal pendulum style in a thin string , or on two strings in a vee formation to prevent it spinning . Can you cause it to take up a position with the string NOT vertical? We need to show if this is pure repulsion , or some form of Bio-magnetic effect or other Biological Phenomena . I do not want to appear critical , or perhaps I do in a constructive way . I am one of your biggest fans , but for replication , we need specific info . And anyway , surely my reply is better than being ignored? Please let us know your thoughts on this.  Regards , neptune .
david lambright
the crystal is repelled from any energized PMH...in fact most objects are repelled at these points copper, gold etc...the crystal feels like the force builds or grows....i urge anyone to get their hands dirty and find out for themselves...i think i have tied everything on a string and held it above a PMH....my brothers tungsten wedding ring had a good reaction on the PMH...i would use a standard PMH to start anyway....david
david lambright
hey, this is part of a thesis/ theory that i have been working on forever it seems...i think that these ideas will change physics...i hope you too will find simple answers to the problems that plague the classic and quantum models...  there are 2 energy streams and they are polar by nature....the singularity is split into a ring...this ring is bi-directional, super-fluid and equal, effectively cancelling each other....twist this into an 8 [infinity] and you have two lobes..take a pen...draw an infinity sign...there are 2 streams so draw it again...the streams still cancel each other...take your pen and draw that sign again this time draw  two circles on top of each other and then at the point where you started and draw two more circles finishing the infinity sign...you see the lobes do not cancel now but you have a direction to move from< the point>....move either direction and we have attraction/repulsion  N and S,magnetism etc....movement causes this  attraction/repulsion so one lobe is bigger ...doppler...[that is why one pole is stronger}...so now we see that from the singularity we get a ring [or disc]  bi- dimensional/directional..add movement and you will have time behind you, space ahead....the only reason we experience any of these forces is the difference in lobe size ...due to acceleration/spin,one lobe is dominant [red shift problem]....this theory was written by david lambright on Thur.1/20/2011... we KNOW about super fluidity, conductivity etc...these forces are all easily manipulated...convection is temperature dependent  but bi-directional....the floor you  stand on consider even or rest temperature, and one foot =1 degree....bring a point into the room five degrees warmer, and you will have a spike or if colder a pit...vortex/anti vortex...convection pulls down the point till it reaches an even temp...this is the same mechanism that is gravity....one lobe bigger than the other to create the attraction/repulsion that we feel as gravity..there are two supreme forces that all the forces arise from ...the math will prove this....    ...the 90 degree or linear to radial interaction;...a particle, at absolute zero, moving through space becomes a line....any interaction with anything takes  energy from it, but since energy can only be transfered,any interaction with a boundary, turns into rotation, bi directionally....there will be a lot more about this and the experiments that led me here....thanks...david
shylo
Hi David , I first heard of leedskalin when I joined this site (not very long ago) and have been reading as much as I can. I've watched a couple of your videos ,the one that sticks with me is the one with the squished pieces of galv pipe, but I need a link to detailed construction so I can replicate. Could you or perhaps somebody else provide me with the link(s)?.........thanx for any help ...shylo
