a new kind of visible radiant energy?
Started by david lambright, August 17, 2010, 04:01:43 AM
0 Members and 27 Guests are viewing this topic.
do you like this topic?
yes, i will tell others about it
 no, it is BS
david lambright
division IS reverse multiplication......a spherical reflection that is illogical....try this...divide 3.14 by .314 = 10...now press = again and again keep going......watch the #s grow from the decimal point.....they will get bigger till they collapse back to 1....the first digit stays in the 10s...bouncing around like an elliptical orbit......or divide 1.1 by .1 = 11....press = again.....try this one 9.9 by .11....or 1.2 by .12.....keep pressing =and see where the go some #s seem to bounce around .....others spiral out Pi is the spiral to infinity....think of like this...a globe with Torricelli's trumpet puncturing the globe , small end of trump down...the mouth of trump 1/2 the diameter of the globe .....now think of the edge of the mouth as row or circle of 9s....and the shell of the sphere is also 9s.....the trumps inside goes to infinity...the sphere having a measurable surface......you cannot by nature, measure infinity from a non infinite point of view...math tells us of infinity i am going to show it......david
MasterPlaster
David, Thank you very much for trying to share the information but I have difficulty reaching the links you have posted. Typically: http://www.google.com/imgres?imgurl=htt ... ,r:3,s:168 is a shortened version of the real link and the "..." in the middle could be anyones guess. I know you are trying some fascinating discoveries and feel frustrated that I can not read up on them.
Many regards
M
neptune
@David Lambright .You are obviously a gifted mathematician . My maths is of a standard that I can calculate all the things I need in everyday life , and in any experiments I need to do . Ohms law i can deal with . I suspect that puts me in the top 10% of the population . Let us not forget that mathematics is largely an abstract thing that attempts to model reality . Myself , and probably the majority of readers here are first and foremost interested in practical demonstrations of phenomena . The maths can come later to quantify these phenomena . Also bear in mind that many of these mathematical coincidences only exist because we use a system based on ten . If we were to change it to a 7 based system say . These coincidences would vanish , probably to be replaced by new ones . What i am saying is this . You levitate , and then I will be prepared to listen to hours of theory to prove just how far your feet are from the floor .I am reminded of a Limerick .
          A young mathematician named Hall
          Had a hexahedronical ball .
          And the cube of its weight,
          Times his pecker , plus eight .
           Was three eighths of five sixths of f*ck all!
sorry , couldn't resist it .
david lambright
the moon at coral castle
is not a moon ...it is an orbit....i have made an iron oxide ring using foam insulation as a mold ....i energized it 2 times ONLY....at exactly the point of the CENTER of the lesser orbit...i found something quite extraordinary!....at that point, there is an energy vortex that is TANGIBLE....this energy is REAL....all the greats talked about it, the ancients used it ...Hutchinson,Tesla, pioneers in new energy methods showed some of what it can do....a PMH energized 2 times reverses the normal convective flow, hot/up, cold/down...heres the thing, what good does that do? gravity is that exact flow....i have tried to show this  the flame or the upward convective force is anti gravity...i think we all agree on that...here lies the question..is that force, hot/up, cold/down, tied to temperature ??...the fact that any rise of temperature creates a convection current to equalize is insightful...if we could get something sufficiently cold, it should resist gravity and flow up..supercooled helium does exactly this...this is fact...but it is difficult to bring the background temperature down enough to achieve anti gravity...superconduction is antigravity....oxides make the best superconductors this is also fact....a PMH made of Fe3o4 will retain its orbiting magnetic energy indefinitely.... the energy can be seen when keeper is removed....this is fact...when the PMH is in the energized state, this force, magnetic in nature flows freely in the center of the PMH material.....think of it like an infinite spring ...in the PMH it is stretched thin always spinning forward with a right hand twist....when the keeper is pulled off , the spring coils wind out getting big enough to affect the copper coil, and lighting the bulb, for an instant....this is fact...the force IS there, and is magnetic in nature, it flows super conductive INSIDE the PMH...are you in agreement so far? ..when a PMH is energized, there is helical spin of magnetic energy...this gives rise to a directional temperature flow....hot/up, cold/down, but not necessarily in that order....in an ambient or even temperature, it does not take much to change convection direction it would be impossible to do so otherwise....there is a balance point....if you can get the flow started at the balance point, it will continue to flow that way .....so now, cold is up and hot is down....try to visualize Eds rotor, at the plane, a disc extends outward, at the poles a line ...where the line meets the disc, a funnel or vortex forms on both sides...an anti bubble, a vacuum, a cavity in space.....now this is where it gets tricky...ok so the convective flows are reversed, there has to be TWO flows, direction does not matter at this point, but GRAVITY is still uneven...to reverse gravity, you must start at the balance point.....remember the Sumerian pictograph? ... the figure has his foot on the balance point, the gravitational balance point...[zero point]....the PMH is real ...the magnetic energy it holds [orbital motion] is real....it is super flowing at room temperature [it flows indefinitely] is also true....the PMH, creates a dual orbit of energy...to utilize this flow, it must be harnessed... just as you siphon water TOWARDS the center of gravity, the flow away from gravity must start in a siphon....where it enters the metal wire, [hook above the pole]it is a vortex, HOT now being the down flow [at the PMH] starts a whirlpool at the hook siphon and starts to flow......is any one grasping this?...i KNOW that there must be other replicators that have come to these same conclusions by experimentation....my devices radiate energy this is a FACT.....the mechanics are being explained so anyone can understand......more soon.....david
david lambright
axicon lenses
my re-discovery of this energy [Leedskalnin] goes hand and hand with spin field theory...there is plenty of stuff about it online....think about why i could not measure it, but could SEE it with my eyes ..this is not something i made up, this is just as real as you and me and the Earth we live on....the russians were using ferrite magnets....i am using a ferrite core , energized like a PMH, and getting the SAME type of results!...this tells me that the force responsible for the effects DOES NOT reside in the permanent magnets but in the deeper force, the force we KNOW exists, orbiting inside the core of a PMH....we know it is magnetic in nature, but gravitic also....one might argue that it is an electric force, but we also know that electricity is not a fundamental force.....i was reading about axicon lens properties and i think that might be KEY in utilizing this energy....if you have a PMH, and a couple of binocular prisms, try this...hold the prisms, widest side facing each other, start about 1" apart and bring them together, with the charged PMH nearby.....i wont even say yet what i feel till a little later after you have been able to try this...interesting....i assure everyone who reads this, i do not have anything to sell, i urge you to find out for yourself, there is more than meets the eye, and deeper things still, than we could ever believe, the only limits we have are ones we place upon ourselves......david
