a new kind of visible radiant energy?
Started by david lambright, August 17, 2010, 04:01:43 AM
do you like this topic?
yes, i will tell others about it
 no, it is BS
sm0ky2
@David
i just wanted to touch briefly on the hot/cold convection forces up/down ect.. and why they behave the way they do.
this has less to do with "defying gravity", and more to do with bouyancy.
When heat energy is added to a substance, be it a gas, liquid, or even solids; this energy causes the atomic/molecular structure to expand. The mass remains relatively constant, however its volume increases proportional to the energy.
The result is that the Density of the substance decreases.
When this density becomes less than that of the surrounding mass, then it will "rise" do to bouyancy. This is the principal by which a Hot Air Baloon operates.
These changes in bouyancy are not restricted only to temperature.
  The same effect occurs when other energies are added to a material.
for instance, when you add electrical energy, the atomic/molecular structure will expand in much the same way. In the moments just before certain lasers begin emitting photons, the medium (if allowed to freely expand) becomes less dense - just like a hot air baloon.
In theory we could create an electric-air baloon, or even use other forms of energy to create similar effects.
The reason i am making this distinction between bouyancy and gravity, is because i believe this describes the source of the "convection currents" we are observing of charged particles flowing into/ out of/ around - these ring-shaped devices we are experimenting with.
What is unclear to me at this point, is how and what type of energy is actually being transfered between the PMH and the external materials.
I think once we unlock this mystery we will understand more about why non-magnetic materials are being magnetized.
When im showing this to someone, and am asked to describe this energy, the best i can come up with is that it is an:
       electro-magnetic energy, operating at an atomic frequency
         (more specifically,
            at the frequency of the magnetized core material)
and, while this suffices for the purposes of the conversation, i cant help but feel that there is something more to it that i havent quite grasped yet..  anyways, i hope this sheds some light on the subject of the hot/cold, up/down thing,
rcsquared
@ David, have you devised a way to isolate this 'energy'? Can you mask the wheel while it spins? That might take "optical illusion" out of the equation. Can you suspend the rock or weight from a hanging scale and determine if there is any reduction in density?
david lambright
a visualation
if i imagine being underwater and the force i am trying to use is air rising, bubbles....by themselves, the bubbles can do little work, BUT just like water can be siphoned, air can be siphoned!...so now i have a means to concentrate and direct this flow of bubbles, through a hose....as long as i have a supply of air to siphon off of, the flow will continue.....OK so now think about it this way, the energy i am trying to utilize is like the rising of air, but instead of air, the flow is magnetic current...this energy, as Ed has told us, likes to flow in metal...to do this, i need a reservoir of this energy to siphon off of... this is where Eds generator comes in. when this device is spun, magnets are thrown off WITH the gravity, representing the downward flow, because there is ADDED gravity, there is also added buoyancy, like a bubble in the center of the device. right above the center, there is a small hook that i believe is a metal "hose", that is siphoning the opposite force from gravity....now i can have a concentrated flow through a wire......does this make any sense at all?...david
Lakes
pause the video at 4:36 after the wheel has stopped, then play from there, optical illusion when you watch while the wheel is spinning and then stopped, I think.
equityboost
