a new kind of visible radiant energy?
Started by david lambright, August 17, 2010, 04:01:43 AM
do you like this topic?
yes, i will tell others about it
 no, it is BS
david lambright
hi ....i have some cheap solar cells, i do not know if they are the right ones...i will be checking...i found some large aluminum tube, 1 1/4"...it will have to be machine bent into a circle...but first i must make jesus's oxide core device...tonight...david
Rosemary Ainslie
Dear Dave,
I have just dipped in here for the first time in a week.  And I promised I'd get back here last Saturday. I'm so sorry - but I see that this thread has taken off and that it's getting the interest it deserves.  Very nice.  ;D
I'm knee deep in all kinds of things.  But it's to do with magnets mostly and I'm probably tied up again this weekend.  Just KNOW.  You've inspired me to try all sorts of things and I'm entirely satisfied that you've got a real EVENT in that Lambright Effect.  Keep up the good work.  When I've got more time I'll fill you in on where I'm going with this.  I might add that you work has also obliged me to rethink the structure of a toroidal field.
Kindest regards,
Rosie
@cletushowell - I wonder if it would be better to keep this subject on topic.  I periodically dip in to read your work - but I'm not sure that it's relevant to Dave's subject here.
sm0ky2
Quote from: david lambright on August 26, 2010, 09:52:21 PM
Dave,
what i mean about the alimunum, was to put it into the field.
and observe what happens, copper would have a similar effect
perhaps do some voltage measurements across a pirce of metal, one end in the field, one end outside.
my daytime is complteely consumed by work right now, so i havent been able to finish cutting my pipe pieces.
so i may experiment with a few other design ideas i have. out of parts i have laying around, until i can cut this pipe come more.
Dave, your concept of the PMH as a "toroid" has opened this thing into a whole other realm. when Ed wrote about the horshoe-shaped device, and i saw other people's builds of the PMH,
it never even crossed my mind that his generator itself was a PMH!!!
the looks are so much different, but when you think about it "magnetically", they are exactly the same.
We can build this in virtually any design.
david lambright
hi rose....it keeps getting better!....i am making an oxide core device for you/colleagues to test...jesus, your device is finished!...it goes in the mail tomorrow!.....i mailed jetijs his device yesterday......i will get to matt soon also....where is bruce?....i know he has good oxide, from his videos, has he made an oxide core device and is experimenting with both devices!!!   really i do not know what has happened with bruce.....thanks everyone.......david
jermutin
Quote from: sm0ky2 on August 23, 2010, 11:40:47 PM
there's an electric charge'flow through the center and back around the outside. the direction of magnetism determines wether it flows top to bottom, or bottom to top.
the way mine was set-up, a positively charged particle is sucked down into the center, like a toilet-bowl, swirling around.
then pushed back up around the outside. (see picture 1)
Let me get this straight. :)
Did you sm0ky2 set the device up, and test it with a charged particle, and the particle was sucked in to a vortex in the center of the device, and went through, and then it came up around again?
If this is the case, this is some heavy stuff here!
I know it has been mentioned somewhere in energetic forum or here, but what was the exact specifications and quality of the iron tube again?
