a new kind of visible radiant energy?
Started by david lambright, August 17, 2010, 04:01:43 AM
do you like this topic?
yes, i will tell others about it
 no, it is BS
sm0ky2
great work dave
have you tried this shadow experiment using different colors of light?
im interested in seeing how red light responds.
but ideally, you want to get a multifunctional prism, that you can change through all the colors, and project each one onto the device to make the shadow, to see how different frequencies respond.
sm0ky2
im not sure what this is called, ive only used it once.
maybe someone in the optical field can help you find one.
basically light enters the prism, and is split into frequencies at different angles.
theres a screen on the end which has a hole in it,. that lets out only one set of frequencies at a time, and you can slide it down through the entire light spectrum.
[and if you block off 90% of the screen at either end, at the edges of the crystal, you get into frequencies "just outside" the normal human range of vision. Each person is different as to how far out purple or red that they can "see".]
david lambright
temperature
if you think of this like temperature, imagine a room, and ambient [neutral] temperature is a plane [horiz] in the middle of the room. one inch equals one degree difference, up or down. when temperature of an object is higher than the surrounding air, it will radiate an upflowing convection current that distorts the image [like a mirage does]until the temp is neutral again .one inch/degree is not much, but if there is a large temp difference, there will be a large flow. with these devices, the energy flows this same way. the farther away from neutral, the more flow can be made. when these devices are spinning, they can throw off extra G energy, and push up extra L [levity] energy. if i use the same neutral point for gravity, i can make an analogy. at earths surface, an object has more of the G in it, giving it "weight". if some of the G is removed, L will be added, and if i get enough G out and L in, i can get an object to be neutral [buoyant]. this energy permeates everything and is what fluidity really is. i held a small chain at the N pole and at ONE single spot above [off axis], there was enough L energy to lift the end link up just a tiny bit. if i place the wire hook at that same place, and put a magnet on the ground rod [tube] at the equator, i get a small flow happening, up the wire into the chain and back into the air. this is visible and distorts the visual like a mirage does. just like heat does, except no heat. although there is a "warm" sensation where the L upflow is happening.......more soon, david
david lambright
Quote from: sm0ky2 on June 28, 2011, 12:59:57 PM
there is an old frequency/spectrum chart by westinghouse that shows a point where quartz goes "dark"and forces start to diminish or increase? i would like to experiment with one of those prisms !! thanks smokey...i will find the westinghouse image, david
david lambright
Quote from: david lambright on June 28, 2011, 07:57:57 PM
http://i276.photobucket.com/albums/kk15/fuzzytomcat/ElectroMagneticSpectrum1800.jpg
