a new kind of visible radiant energy?
Started by david lambright, August 17, 2010, 04:01:43 AM
do you like this topic?
yes, i will tell others about it
 no, it is BS
gadgetmall
david lambright
Quote from: ariovaldo on October 25, 2012, 01:01:15 PM
Hello David !! A stupid question for you: Have you tried copper tube instead aluminum?
not a stupid question at all, but yes, i have a 3/8" copper tube filled with Fe3o4 iron oxide. I can not say it is better than the aluminum, but it does generate a field. i also have a mercury filled tube,[1/4" clear vinyl]that generates a visible field also. the battery i use is a 9.6 volt battery from my makita drill.
ariovaldo
gadgetmall
Where did you get the iron oxide?I have an aluminium tube. The real question is do you even need a ring? Can you see Aura's on people? I can but i cannot see those waves with magnets . There must be a condition to see them?
gadgetmall
Hey David,
   I have an idea to magnify then waves . Have you tried to cascade rings spaced on top to see if a more larger wave can be produced?Also Pyramids in the center ?
