do you like this topic?
 no, it is BS
Hope
If we are seeking physical work done from our devices, using electricity is only one way of doing the job.  We are going to have to design what will look pretty weird to the masses at first. But when they understand it is just using a newly (re) found radiant energy, they will comprehend it no problem.   Our normal electricity theory based test equipment won't be of much use to us, so I look forward to the new tools we will be discovering.
sm0ky2
As Ed teaches us, a constant flow of electricity is not necessary to sustain a magnetic current.
if these affects are caused by the electro-magnetic features of an HV-field, then it may very well be possible to do it without electricity.
Dave,
          Your unique perspective of Ed's wheel has led me to realize something important...
An affect i observed many years ago, is in fact a variation of Ed's wheel. I had just never looked at it that way, because the physical design is so diferent.
Consider this for a moment, each of those pipe-segments is forming a seperate magnet.
N - S at the "gap". horizontally polarized.
the flux-path  creates a spherical vortex, causing this energy to radiate upwards through the center, and back around the sides to the bottom. like the EMF from an active toriod.
If you examine an arc-type path around the outside surface, from top to bottom, like in front of the "gap" that area between the two magnets is of great importance.
I would suggest tunring a permanent magnet perpendicular to this field (north and south up and down), and pass it along the arc in front of one of those "gaps". and observe the effects. if i am correct, this should behave similar to a graviational 'orbit'
I will begin construction of one of these devices as soon as possible. My idea is to make it smaller, to concentrate the effect.
and also to create one very large one (maybe 4-inch pipe?),
to observe this on a grand-scale.
sm0ky2
Quote from: Hope on August 21, 2010, 03:12:18 PM
It may not be as complicated as it seems.
i read a paper in the early 90's, that theorized two sides of the electrical current.
the unidirectional force that we utilize,
and an equal and opposite force the other direction. (negative current). There was of course so physical apperatus by which to test this, all of our equipent is " one sided".
I bring this up because, as Ed states, the magnetic current runs the same way, in both directions.
It is this interaction, i believe , that is causing this new effect we are observing.
the flux paths here, are not completely closed, like in the PMH.
they are broken on the outside of the loop.
but the inside is closed.
this tells me that the two mangetic current paths should be running at two different speeds. Or at least completing their loop at two different times,. the point is, that they are not just pushing/pulling on one another, but actually passing each other.
Could this be the cause of the new "magnetic heat" ?
we need to find a way to interact with this field directly.
perhaps multiple devices, with the fields facing each other?
could there be a material, we have not tried yet, that can interact strongly with the field?
What is the outcome, when dropping 2 objects in free-fall from the same height?
one object in the earth's gravitational field alone,
and the other object falling through this new field.
do objects still fall at the same rate?
if not, this may be some form of "gravity wave radiation".
i have doubts about that line of thinking though, i do not think "gravity" comes in the form of einsteinian waves.
i believe this is another dimension of the magnetic effect.
magnetism, electromagnetism, "gravity",
and this new one that, unlike the other three, appears to be at least somewhat in the visible spectrum. or perhaps interfering with the light that passes through it. either way, we can "see" it,.
where as, we cant see the other 3 types of fields, without the help of some kind of "viewing device".
is it purely optical in nature? could this be some sort of low-frequency photon generator? like around 403Thz, just on the line between infrared and visible light?
Or could this simply be magnetically orienting the atoms/molecules in the atmosphere around the device? causing them to diffract light differently than normal "air".?
i think figuring out how to interact with this stuff is going to have to be the first step in determining its nature.
Hope
Well if there is a front radiant focus maybe there is a reversed flow in the center of the device.   This observable phenomena is different than any other topic and I believe it deserves its own thread, as for me the island recyclers had the materials just a waiting for me yesterday.  My neighbor has a chop saw so I guess this will be going together soon and I will TRY VERY hard to get pictures and scan them (not digital)  I think this wave is so faint the camera makes it look like pixel variance from camera motion but it is NOT.   Even if the camera is mounted ridged this was still happening.   Can you explain how you magnetically locked the wheel again,  wire gauge..how many turns.. where..  what size battery ..... which pole to which wire?  It LOOKED straight forward, but I want to replicate your creation closely.   And as for seeing it on your videos David, I could see it best on your outside in the yard shots with you holding the rock and spinning the wheel, hope someone with a real film movie camera will capture this sight due to it's a lens device also.
