Please BAN and remove all posts from user cletushowell
Started by FatChance!!!, August 17, 2010, 07:50:53 AM
sm0ky2
Quote from: cletushowell on August 27, 2010, 01:38:12 AM
music is not my thing
if you explain it to me I might get it
im not a musician either, but simply put
the "low F" should be 171.19Hz
for most people, the human ear cant hear the difference
its because of 'where we are' in the universe.
the band in the center is not perfectly centered, its off towards the "E" side. but its a 3-dimensional scale. most people try to look at it in two dimensions.
and tilted downwards towards the F.
basically what im trying to say, theres a fractal octave shift, starting at the first node. so on one side, instead of it being 1
its really 1.337421875, which graduates to the "F" that we can actually hear several octaves higher.
they're all shifted to one side like that, on the 3-d scale
the proportional relationship between the frequencies determines how much it is shifted. but it all starts between the first two nodes. one side (E) is closer to the "center" than the other (F).
this proportion keeps comming out like the damn plank fraction
but im not really good at fractions, so i havent been able to pull this one out yet...
thats the best way i know how to explain it.
Mk1
@smoky
I think you found 3 , from the 369 ...
This could help everyone and guess what music notes are inserted ...
http://www.ardue.org.uk/university/system/lect37.html
sm0ky2
@ MK
wow thats creepy, look like 3/4 the way down the page
cosmic octave
Sol, La, Ra, Fa, Mi
are the 5 points of the pyramids,
that represent the 5 powers of the gods.
Sun, Water, Earth, Fire, and Wind.
( i may have the order mixed up on those)
cletushowell
Ok I know why your stuck and confused
its imposible to do in one sided math
which is what all math is one side
because your going forward and back
2+2=4
4=2-2 forward back
2-4=-2 back
-2+4=2 forawar but no code
only linear math
what me and marco are trying to teach you
is the math does not go forward and back
it goes in loops codes sidways
the codes equal other numbers hence there
the same marcos system is very good
you see his loops but its wrong
the 9 does not loop back thru the 3 an 6
well it does but his loop is only 936
he did not do the 144,000
the top and other side the all numbers loop thru
8 hess stuck in 11 because 11 is 1
acording to his patterns but he doesnt cary
his pattern 144,000 times thats why its a number
no man can count becauss 1 is 144,000
144,000/1= you see
but how do you get back 11 to 1
you cant its 144,000 x11
1,584,000 well you can have 11 and one
but not without 8
1, 5-4=1 =11,8=19
which =36918 now your always in 8
all numbers are 8
basically Im seperating heaven and hell
if you wish because 8 will always live in
88=16=7
888=24=6
it goes on but all this for your answer
your 144,000 is not stationary between
red and blue its bouncing so go speak
or rather things bounce around it
even 369 but they have there own axis
i guess you could say this is the protons ane electrons
not shure which but one is in the axis of 369
one is in  the 8 a wheel inside a wheel within a wheel
144,000 is your nucleus
369 is the gyroscope
another 1 is you all numbers of 8
so between e anf f you have one middle but
which i gave you but mitiple middles as well
2+2 = 4 3+1=4 1111=4 ect
your codes you cannot get in regular math
because you would be doing this 144,000
ways before your done
confusing i know thats why I start at the answer and go backwards
cletushowell
As far as haarp this is what there doing is it being
used bad or good probly depends on whos running
the haarp
we all know harmonics change how you feel
any good muscicians knows the harmonic to play
to make groupies want some and because
groupies all get the same harmonics at one
they not only love there job but love there sex
now haarp is using harmonics
to manipulate you to love your wallmart
love your shitty goods from china
reverse the harmonics and programing to make you hate returning
items you found out you didnt love
but bought because them when your drunk
essentialy like fucking the muscician
after he serenates you with a nice melody
then next day saying dam i just fucked a guy
that had sex with hundred of girls whats wrong with me
well now you see haarp is the music of the world
they can make you kill each other by
playing off key like listening to karoake
or love each other but what they dont understand
is you cant have joy without suffering
you cant love without hate and there is no
perfect world and so for every good thing they try
theres a negative result somewhere
put possitive somewhere else
just happens you see haiti but not all those that
got to give from there kind hearts to help
every one remembers the atomic bomb
nut no one remembers grandpa flying the
aid over the wall that feed everyone
wich saved more lives then the bomb ever killed
I didnt research the numbers firgive me he spent many years
rebuilding that country to watch obama
give a speach at the wall about his grandfather was a british
paralament cook ya that was pretty hard
hes our president and does even have a clue what or why
I guess Grandpa knew best. Well im off topic ill
go try to build that coil again
