Please BAN and remove all posts from user cletushowell
Started by FatChance!!!, August 17, 2010, 07:50:53 AM
cletushowell
Well that probly where the antenna should go
its not done ill tell you that but its closet
ive seen if the oscilation was pulsed
to that overlimit spike it could easily transmit
a whole town but in the 60 hz its limited
its possible i did it twice but duplicating it is
turning difficult for some reason
cletushowell
By the way im pretty shure
if you reverse those air batterys
like the car coils put the zinc spiral
inside like the hutchesion and moray cells
the the frequency is contained
the moisture is contained and it should
realy store energy as the frequency is trapped
cletushowell
These circuits work in reverse
some how instid of the battery charging up
the coming down to go from earth
to power we have to charge down
to go up the antenna some how
with morray removed the energy
from the cells so it starts going
once it goes down 369 is removed
it continualy builds up instid of building
up then always going down go down
then always go up its reverese hard to
understand I know so our batteries
and juel theif dont go negative
enough but some how thru the circuit
i dont really know how the circuit works sorry
but it must offset the dead battery to manilulate it to below zero
should go exacty 1 below zero point
to start the flow
FatChance!!!
Wtf are you mumbling about ????????????
Anybody here having a clue?
cletushowell
Seriously is it like a war against stupidity
if you charge a battery it goes dead
im talking about reverse energy
taking the battery negative so when it essentialy
goes dead its actualy always useable
never ending
the air battery is wrong hutchesion
nor moray put the spirals on the outside
of the gemanium or granite or minerals your losing your frequency to air
