Truck claimed to run on 100% HHO in Prescott, Arizona
Started by Cisco, August 17, 2010, 04:33:32 PM
mscoffman
Check this PWM controller - looks like the same board, Web Link;
http://hydrogenboostnow.com/50ampboxgauge.htm
Those are connector spade "pins" behind the heatsink.
Fans are to keep the heatsink cool. We are not alone.  :)
This net device seems to have 6x times Faraday yield - enough for
most road situations, apparently. A couple drops of HC never hurt an
ICE engine though. Is still think the "geometry" of the electrolyser
may need to be nearly exact for it to work.
:S:MarkSCoffman
Gwandau
Found this PWM, which I believe is by far the most heavy duty high current high frequency range for sale on the net.
http://www.hydrogenboostnow.com/100amp.html
I haven´t seen any other high current PWM with a range from 300 to 15000 Hz, so this i beliewe would be a nice alternative
to the PWM used in the video.
I have mailed to the Arizona Electronics for more extensive information about the PWM:s they sell. That way we may
more easily identify the PWM used by Frederick.
I mailed him some days ago about the risks he and his associate are taking by exposing their identities, and stressed
the importance for open source since this would probably keep him safe.
The adress I used was this:  futureenergyconcepts@cableone.net
He answered me this:
"You are so right!!!  I tried in 1982 during the gas crunch, with alot of opposition, decided to give it away to varried websites and personel,
whom haven't done much with it for the last 30 years. If the new concept is not open source-ie: our website, let me know how to make it more so! "
So he will probably in a short time respond to the mails sent by you.
But I think we have to calibrate our PWM:s ourselves in getting the HHO-system to resonate properly.
Just keep to the correct distances between the tubes and follow the other parameters given by these
friendly guys, and we will also succeed in getting 50+ liters per minute!
These admirable guys are genuine. Just hope the stay sound and safe.
Gwandau
Cloxxki
From what I've read, seems the real trick is the ionization they use, to multiply the combustion power of the lpm's they are getting.
If ionizing is an OU way to boost the power of HHO (these guys use atomic H apparently), then the world IS saved...
lefferdink
Can you fellows keep me posted on this matter?
I built an 18"X8 316L Meyers cell and have to fix a leak in the bottom electrical connector.
Sprocket
Somethings been bugging me about HHO production and it has probably been answered before - if cells produce much more gas in a vacuum, why are there no commercial cells fitted with a small vacuum pump???
