ventilation in solar panels
Started by guruji, August 18, 2010, 03:27:43 PM
CompuTutor
Sadly, the combination of two green technologies
that have been available seperately for quite a while,
have failed to appear together in unison as a team.
On the one hand there are solar panels,
on the other solar heat harvesting panels.
I've been waiting for someone's noodle
to realize they've always belonged together...
Take a standard sheet-by-the-roll of
over the counter copper roof flashing.
The thickest you can find.
Unroll and cut into appropriate rectangular sizes
that would be a little larger than the matrix of
solar cells your planning on implementing.
Now take soft small scale soft copper tubing,
1/4" seems about right for a high flow rate.
Place the copper sheet on a piece of plywood
and using a tubing bender for tight bends
begin to tightly cover the sheet with rows.
Due to the limit on the bend radius of tubing,
some creative interlocking patterns will be needed.
Once a maximum (Reasonable) pattern has been formed,
get out your hand torch and solder it to the sheet.
Flip the sheet and bend the edges up to form a tray,
and solder the corners to make is leak-tight.
Mixed some two-part potting product
that comes by the gallon inexpensively,
and pour it into the tray
Take your pre-formed rows of solar cells
and lay them in one at a time,
working out the bubbles.
When it hardens, connect the rows together,
and pot the upper and lower connections too.
With the potting product in full contact
with the backs of all the solar cell rows,
condensation is prevented from occuring.
Also, the same potting product will conduct
quite a lot of the heat to the copper backing,
were the tubing can carry it away for use.
The dark color of todays cells assures a lot of heat,
so even though the potting product may not be
the most efficient heat transfer compound to use,
it will still do a considerably better job for us than
using absolutely nothing like we are currently doing.
Create an edge box frame and put on a clear front,
lower the the panel in solar cell's facing down,
and fill the back couple of inches with some
stir-and-pour expanding foam insulation.
Get or borrow a vacuum pump for the front,
and wait a week for all products to fully cure.
There are many things above
that can be picked on for sure,
I don't care at this point frankly,
I'm getting sick of the negative minds here.
I'm tossing a concept out there
in simple layman's terms for ease
I chose to write it in simple terms
to keep the length down a lot.
Run with it...
DreamThinkBuild
Hi All,
Dan Rojas did a test with putting a solar panel submerged in water. The temperature of the panel makes a huge difference in output.
http://www.youtube.com/watch?v=rGi0Mf3cl1E
Hi CompuTutor,
I like your idea. I noticed that on my array the panels get extremely hot on the back. A idea I've been toying with is to get thermal paste and mount Peltier modules to the back of the panels with a aluminum heat sink on top. This way you could collect both solar and thermal energy while wicking away heat through the heat sink.
CompuTutor
If you sealed the heatsink tops
and flowed water through them
you'd have something there.
That would maintain the thermal differential
required for that application to perform well.
The cost-verses-recovery ratio sucks,
but peltiers can't stay costly forever.
Then again, the manufacturers of peltiers
could just add the darned P/N stack
on the back of PV's in the first place...
That would yield BOTH photvoltiac and peltier
recovery of the suns provided available energy.
We would only need to employ
fluid (Heat) sinking to the back
to maintain the thermal differential
that harvests both heated water
and two forms of electrical potential.
I've been asking peltier manufacturers
here and overseas to make tubular ones
for years now, they don't see the need.
The inner and outer tubes would be
both the conductors and the thermal surfaces.
Some are entertaining the idea somewhat.
Mount them in a third tube to provide
the second sealed outer passageway
and your in business.
Basically and it is just an intercooler
with a P/N junction medium.
Sure would be great for GEET/Exhaust work, etc.
Then again, if you've ever used a clamp-style
ammeter on a geet, there is truely awsome
and extremely high gauss values available
to be harvested already around the reactor...
