Ok help me out how do you build 120 volt 100 amp battery
Started by cletushowell, August 22, 2010, 09:34:49 PM
cletushowell
My wireless transmision aint going be no good
unless we store the energy so I need a good
easy system to build a 100 amp 120 volt
ac battery so it can charge and gave enough
juice to run everything im getting about
8 amps out and less the 1 in so im way overunity
but the coil either needs to be bigger
or some manipulation of a storing
battery and best part is when you shut off something
it sends power to grid its reverse of turning
on a light when you turn it off you generate
power breaking the point Gap
cletushowell
Maybey
ten car coils would increase the
watts that way or maybey 60
inline oh i got it 1 in 2 out split those two
to two more this should magnify the
wattage what do you think or maybey
3 coils 6 coils 9 coils back to 1 wire
that should run anything
dllabarre
cletushowell
Ya im definatly steaming
i think it be easier to build a dam steam engine
from my forehead ok
anyways i got it turning the motor
a small razor need to paralel both sides the secondary
to the same side it doubles the watts
but when i go to another car coil
it goes thru and generates more energy
but get this it does not raise the
speed but generates another 80 volts
so now with three coils i would be
60 volts on neutral side 120 on
primary wireless and 80 volts on secondary
but if i ground the secondary
it some how caused a magnetic induction
stops the razor but none of the volts or amps change
this has got me pretty baffeled
how can volts go up overunity and the
whole thing stay at less then .01 amps half time its zero
if the secondary some how charged a capacitor
wireless or a magnet of some type
then instid of it stoping the motor the extra 80 volts
would be building like moray said
because it runs the razor the whole time building the extra 80
volts but the watts is now the problem
first dc volts then ac volts then hz
now watts after that is there anything else?
Shit and can the razor change the oscilation
by putting it in line and lowering or rasing volrage to adjust speed
maybee it can oscilate my overlimit coil
cletushowell
If you can understand feedback you can understand
my enerygy suupply is only limited
by my speaker not by my amp
because my amp is unlimited
but my storage is hard to
do so far i see no 120 v
or 240 v battery but short life capacitors
and dc voltage junk lead acid cells
wich purify with photon
so im going to have to build a better system odviously
