Ok help me out how do you build 120 volt 100 amp battery
Started by cletushowell, August 22, 2010, 09:34:49 PM
Hope
Careful on the output side.   This unbalance energy will balance with haste so be careful.   It could be that Ed Leeds.. unbalanced battery speech will help us design one of these new separaters...
cletushowell
I allways get in over my head your so close with. The helix idea
the earth batter was unlimited ac and dc
i could not seperate them to use something like a helix
your talking about is needed at least were back on subject
ok the problem with lead is the lead neutralizes the acid
why can we not put a circulating pump with a filter type system
to remove the dirty acid send the
pure acid back basicaly removing the salt
from the system seem like thats the problem to me
seperating salt from everything
ice is a crystal salt is a crystal both must be oposites
in some way
Hope
How does the universe store its energy?  It is AC and DC at the same time.   Natures way not only is 100% efficient  it also can magnify that till ALL ENDS.  So Eds method mimics nature Galaxy in that it is spinning creating constant reacting fields, moving. Reacting as if alive or at least able to sense, so to speak, of its imbalance or balance enough to have correction applied to arrive back in balance (the neutral point).  This "np" is as we see not so neutral since we are part of it and can see it as if we were from a microbes view to a glass body.
The answer is in our hands already about the battery.
What can we do we have not done before with the PMH.
David I bet you know what I am getting to.  Especially since your the first person to post the ability to magnetize non ferrous objects.    I will post it in 10 mins so you all can have time to form your thoughts.
edited
Hope
A PMH filled with a element or elements that can take the heat of a HIGH pulse say like 1900-2100 volts sound about correct Cletus?  Sure is alot of crystal structured ellies could line up for an interview on that job.  Quartz with slight traces of gold salts might be up to the job.   So when you have the container built and filled, you'll have to charge it or antenna it.  Like the battery of the bible the arc.  The part that makes this interesting next to me is:  if the charge is in the quartz matrix then can we make a bunch of batteries out of the charged quartz?
Hope
I know you will have to find specific frequencies  but this seems to be your forte so I am interested in your results.
