Ok help me out how do you build 120 volt 100 amp battery
Started by cletushowell, August 22, 2010, 09:34:49 PM
cletushowell
That was too confusing
7=16
16= 88
just one 8 =7 and a extra 1
the 7 goes back to 16 without the extra
1
this is why ed sweet 16
but i think i can improve it 12 and 11
the middle is 11.5 =7 =16
Hope
Hi All,
Had to correlate natural harmonics and studied a few pattens for this gleaning.
This improvement will help all circuits be more efficient.   On a perfect natural sound wave we need to add to the wave during the movement of greatest potential difference till at neutral.    So at the apex of the rise time on both the positive AND the negative swing.    Truckers no this move well, as the gain speed BEFORE the hill and on rolling hills they gain extra speed on the downward slope before they must climb again.  This helps cut fuel use and engine wear.   On a downhill slope you have all that latent energy electric  vehicles can even charge on downhill slopes.   I suggest that spark gapping the top of the negative going waves but placing a  charge on ground high side of spark gap using a inductive coil or a magnet on the ground side to enhance the movement of charges.
edited
Hope
If we do what we have always done, we will get what we all have got.   So if we can collide the force of the obtained from the collapsing wave into the next rise in potiential faster than its normal fall we help the next rise time.
cletushowell
At tthis point I dont really know the questions anymore
the matrix God created the 7 day first from that seven you can
do anything you want
7x6 =42 ya that was a bunch bs
to get a fucking stupid answer
which came first chicken or tge egg
the answer is the 7 is the fucking middle of
both he made the rest day first and never worked
I guess thats why they call him God
i think your talking about simple implosion
boil water you creat a pressure drop a drop water on
the heat source it creates a vacume
that vacume pull the drop water into steam
faster Im really frustrated
cletushowell
Hope i see youurr ppoint but when not working on a hill
the energy to climb the hill is always the same
but theres a diagnal force that holds the hill
up say the trucks moving 60 miles a hour
ten feet from the top i remove all the diagnol
force implode the hill from the downward weight
taking the energy that was holding the truck up
bonce it a a faster rate higher frequency
back to the top the truck still crosses the gap of no hill
due to its forward speed i see this every day
they drive my truck off the cement and theres a gap between the tires and the ground proving the truck would cross in air but you
but you need to double the oscilation
think of a hill with a flat top theres a v
holding that top up now if we turned the v
we double the oscilation
for example why is the steep hill a zig zag
its increasing the oscilationd spreading the energy
over move mountains instid of straight up and straight down
i beleive you will find the energy generated to go straight up is less the the energy to zig zag why because its direct
and your still climbing the same hill
so if you climb straight zig zag down
your energy has to be incresed everytime
your taking the distance of the straight coast
building it into the oscilations
if you turn the wheels 100 times in a straight
line going up and 1000 times in a zig zag going down your speed going down is the same due to gravity you hit the bottom the same time
no matter the path unless you store the gravity
by directing it and forcing it to charge
over a longer slower rate truckers just coast
dont charge which is stupid to tell you the truth
there forced to slow down going down hills that could be building energy
or hydrogen
