Ok help me out how do you build 120 volt 100 amp battery
Started by cletushowell, August 22, 2010, 09:34:49 PM
Hope
Then we need to jump from hill top to hill top without one of the charge components so it can ride the dip too.  can we place a coil within a magnetic induction (like a PMH charged) to only slow down one componet Cletus some how attract it (invite it) to neutral.  If we can lag one part then natural forces will want to balance back (a radiant force).   Since the HF frequency travels on the SKIN of the wire   if we use hollow wire we can try adding different energy componets within the hollow to try and effect changes.   Thermal,Photon,Sound, air pressures, gases, a center point like the start of any matter.   You know how they clone (grow)crystals  maybe we could get the device to dupe the properties of the contained item.  Then Cletus we would have a new material to work with.  Thanks for the input on vortex math        Keep Well!
cletushowell
Hope I dont even know why im doing all this but
today i busted all the matrix God created the
7 day first the 7 is the 6 7x6. =42
so I got real mad most of the day
because all the math when perfect does
not answer the question its the sacred key to the universe
but the universe is the secret so it can solve anthing but not create itself
so now im calculating the gaps between the numbers
the force between aplles 1 and 2
its not 1.5 a 1.5 i could see so its
a force that has to be calculated with no two points
no two apples if you calculated the sun and the earth
you voukd calculate the energy the time the spin
but if i made earth and the sun invisible
how would you calculate it well I started
by thinking backwards the sun and earth are
a measure ment of the field not the field
the magnets fields work anywhere
the stronger the magnet the better the measurement
but if the magnet = the field it would be invisible
so where do you start to measure the invisible
the fields you cannot see
the time between two points that dont exist
the energy of the empty field from which the 42
began well i decided to do the matrix
of the invisible so i started with the missing tribe the number
that never comes up 12 of 12000
now i get 12 i get 56,000 i get 11
and 7 and 2 but why 12,000
well heres my start it took teslas 333
to get there but i put 42 in the middle from a series of
numbers these numbers would essential
be the invisible field that would create the 42
no one probly understand it but i made 42 the center
black hole the decimal the dot is made from this
sequence of numbers
12000x56,000/9/6/3
 4,148,148.148148148
Left side
4+1+4=9+8=17
1+7=8+1=9
9+4+8=21
Right side
111=3
48=12=3
48=12=3
333=9+4+8
21
21+21=42
X00013
cletushowell
Dad todd saw I King did we Fo Si We'd do it
ya you made no sense to me
at all so i recompossed it
cletushowell
Ok im thinking about this lake battery how
when the nuke plant prduces to much power it
pumps water up to the top lake flows it down when
theres a high demand but if it over flowed the lake
it would just let water back to the bottom
to be pumped up again so the only way to maximize the amount
of distance between energy between the top lake and
bottom lake is to drive the water farther up and farther down
now i see the cap as my lake it gets full very fast
but what if my cap was a higher voltage
could i store more 120 power and discharge it slower
what if I Had a 500,000 volt cap how much
power could I store could It be drained slow instid of a instant discharge
I dont know much about caps but that seems like the answer to me
