Self-Runner NS Coil Pulse Motor Live Video Stream. It's been going for months!
Started by lasersaber, September 01, 2010, 09:59:28 PM
0 Members and 54 Guests are viewing this topic.
Rosemary Ainslie
Quote from: Omnibus on September 12, 2010, 03:16:31 AM
@Pirate88179,
I really don't believe that insulated wires wound in a coil work when placed in a Faraday cage.
Fortunately science is NOT progressed by 'belief' but by experimental evidence.
Quote from: Omnibus on September 12, 2010, 03:16:31 AM...but, remember, sometimes we may be somewhat gullible. This is a serious question and it shouldn't be taken over by amateurs and incompetent enthusiasts.
Golly.  I suspect he may be referring to me.  LOL.  Whatever next!   ;D
Rosemary.
Rosemary Ainslie
Quote from: nievesoliveras on September 12, 2010, 08:13:20 AM
Is it this what you mean?
Open the file on windows paint and correct it as you want it.
Jesus
Hello Jesus.  It's definitely close.  But I got bored with putting in all the coils.  It's meant to wrap around the whole of that half structure and I'll put bobbins? is that the term? at the ends.  I also want to try with the second half of that same pipe - but will delay this until and if I can get the rotor to spin.   Also. The rotor extends beyond the pipe and not as I've represented it.  In other words the diameter of the pipe is marginally smaller rather than bigger than the rotor's diameter.  I only drew it this way to show the actual shape of the proposed core.
Kindest regards,
Rosemary
IotaYodi
QuoteI thought of simply packing that hollow with iron filings
You may be able to pound coat hangers or welding rods into it.
When you couple an inductance to the magnetic field of a power line,that inductance becomes part of the circuit putting a load on the circuit. I cant see electromagnetic radio frequencies through the air putting a load on the transmitter. Unless its proven Ill grab any electromagnetic wave and use it. I just cant re transmit any audio,visual or communication signals. Seeing how radio waves radiate out in all directions it would take a large magnetic field to converge them to one spot. If that happened you would have cars,buses,trains and steel in buildings on top of your coil. If you were still alive you could call it the Black hole coil!
What I know I know!
Its what I don't know that's a problem!
Rosemary Ainslie
Quote from: Pirate88179 on September 12, 2010, 02:35:38 AM
Rose:
I call it plastic because the mag wire I bought said it had a polyurethane coating.  Now, Don says his mag wire has enamel coating, which is probably true.  As far as Ominbus's questions, no matter the coating, this "should not work" unless it is bare wire.  But, it does.
As I have said before from my personal experiments and studies,  I believe there is a galvanic component to this BUT, I also believe there is something more. What that is I can't really say but from everyone's experiments I am confident in my opinion here.
The more folks working with this and posting their results, the more we will all learn what is, and what is not.
Hello Bill.  Here's the thing.  Laser has already tested the insulated wiring as his wires DO NOT touch each other.  He does not - from what I've seen - strip his copper.  Copper is usually insulated.  Therefore the iron and copper are absolutely separate both on and between each of his windings.  So I entirely agree that this much is done and dusted.  The practical, theoretical and actual evidence is, therefore, that the galvanic effect is NOT eliminated with insulation - I would have thought?
Also - to address this latest concern that the 'energy' is coming from RF.  Again.  My knowledge of all things is limited.  But I thought that the principle of picking up RF rather relied on open ended wiring - and there's nothing required to be open ended in any of Laser's builds.  Therefore I would have thought that this could be entirely discounted as a source of the energy as is now being suggested.  Quite apart from which, in the use of any transistor - MOSFET IGBT whatever - then they would, theoretically be entirely distorted by this - as RF is everywhere.
But - again - I don't know the answer here.  But I have a question.  If a radio broadcasts at a certain frequency is it required that the radio station put out these frequencies at ever increasing amounts as their ratings improve?  I doubt it.  2, 20, 2000 or 2 billion listeners tuned into one station makes no difference to the required output.  Which speaks eloquently to the principles of aether energies, in my humble opinion.  It therefore is an unlikely argument to use against OU.  But I suspect that it's largely irrelevant as a description of what's happening here precisely because Laser's rig is NOT open ended.  He's got reed switches at both ends and they are opening and closing in synch with those collapsing fields.
Regards,
Rosemary
Omnibus
Quote from: WilbyInebriated on September 12, 2010, 09:02:38 AM
i see. so your opinion is that if station WXYZ sets up a a "pay" radio station at FM 103.3 and told people not to tune in there unless they've paid, then station WXYZ could take legal action...  ::)
Correct, unless station WXYZ has deals with advertisers and can afford not to charge you. Otherwise it will definitely charge you, as is the practice nowadays. Like I said, similar as in the newspaper industry -- some newspapers are free but many more are paid.
It is not a matter of discussion that whoever taps into the high voltage power lines or a radio station for the purposes of using these as energy sources is in fact a robber, stealing energy from these enterprises. That should be clear to anybody prior to coming to this forum to discuss free energy and OU.
