Self-Runner NS Coil Pulse Motor Live Video Stream. It's been going for months!
Started by lasersaber, September 01, 2010, 09:59:28 PM
IotaYodi
QuoteWhen my coil is dry and the reading is 0-1mV the coil still drives the compass crazy when I pass it by the coil.
Where is this magnetic energy coming from then?
I would suspect there is remanence in the core and steel wire. With higher iron and low carbon in the core the effects should be smaller. You could take a fine needle or a tiny steel washer and see if the core or iron wire attracts it. If it doesnt then maybe the earths magnetic field is involved.
I need to acquire a compass and do a plain totally non magnetic steel core to see if the compass is disturbed by the core..
What I know I know!
Its what I don't know that's a problem!
lasersaber
QuoteI need to acquire a compass and do a plain totally non magnetic steel core to see if the compass is disturbed by the core..
I'm sure it will be.  When I speak of testing the electro magnetic effects of the coil, I mean controlling the magnetic effect by shorting the wires exactly like I show in this video:  http://www.youtube.com/watch?v=lcjxA7bYUp0
IotaYodi
QuoteI'm sure it will be.
I think so too. The earths magnetic field should at least run on top of the iron cores skin even though its weak. I would think if the core were aligned with the earths magnetic north and south,the field lines would run the length of the core making it easier to pick up a magnetic field.
What I know I know!
dllabarre
Quote from: IotaYodi on September 14, 2010, 08:52:01 PM
FYI my core is a ferrite rod that I had laying around.
IotaYodi
QuoteFYI my core is a ferrite rod that I had laying around.
If its a hard ferrite then you probably have remanence in it as well as the wire.
What I know I know!
