Self-Runner NS Coil Pulse Motor Live Video Stream. It's been going for months!
Started by lasersaber, September 01, 2010, 09:59:28 PM
Rosemary Ainslie
Quote from: shylo on September 16, 2010, 07:41:05 PM
This coil is the only thing of importance here...........I have stranded wire eqivalent to 15awg........... I used this in place of solid wire....but no readings and no magnetic fields    ....bare coppper not insulated with cotton............I think the bare copper has to be insulated individuallly by the cotton .......magnetic drive is the way to go............shylo
Hi shylo.  Can't quite understand you.  Are you saying that the stranded copper doesn't work?  That's good to know.  But weird if it's the case.  Just another one of those strange things about this rig.
Would love to see your build if you're up for it.  By the way - I think that Ted has put his coils in parallel and I think I'm going to try the same.  But I'll try series first.
Regards,
Rosemary
shylo
my manufacturing skills leave alot to be desired............I did find out that if you hold a piece of steel facing north and south  .....a magnet will line up with the right polarity............the piece of steel will aquire a polarity.........shylo
Rosemary Ainslie
In the unlikely event that anyone's following the saga of my build - the Pratley discs HAVE NOT STUCK - the glue has NOT SET - and clearly - if Divine Providence is responsible - then I think I'm being told to 'give up'.  LOL.  I have no intention of listening to this advice - not yet.  But I'll defer to some expert opinion here and try something a little more standard.
Regards,
Rosemary
;D
Pirate88179
Rose:
Just use 2 pieces of wood for your end caps.  Nothing says they have to be round, square will work too.
Just a reminder for folks.  If Stubblefield did not have to place these coils in the earth to get the maximum effect, he would not have gone through the trouble of doing so.
Ted Ewert
Hi Rosemary,
Looking at the picture of your coil, it seems that your copper wire is very close to your steel wire. What are you using to insulate the two from each other? Are you using magnet wire?
Ted
Check your PM.
