Self-Runner NS Coil Pulse Motor Live Video Stream. It's been going for months!
Started by lasersaber, September 01, 2010, 09:59:28 PM
IotaYodi
What I know I know!
Its what I don't know that's a problem!
Rosemary Ainslie
Guys?  10 days and no more posting?  What gives here?  Actually I'm as culpable as ever in not coming back here.
Laser can you advise us on the status of that rotor?  Is everything still spinning ? - is the question.  I need to get my own tests up and running.  I'd be REALLY sorry if this thread 'falls off the cliff' as MileHigh puts it.  I shall certainly try and get my test together.  Can you believe it?  I'm still looking for the 'feet' of that core that I've got.  But I've been remiss.  I'll do my best to attend to it during this coming week.  Apologies for letting this go for so long - but I've been up to my ears.
Kindest regards,
Rosemary
lasersaber
The motor has stopped!
Sorry for the delay on posting this.  I have had almost no free time and what little I have found I have put into building and testing.
I did not feel like typing this twice so here is a copy of what I posted in the NS thread.
  I had my long term test motor running along just fine.  It ran for over 110 days nonstop with no added water.  When it did slow down I believe it was because it had a failure at the connection point where the two pieces of steel wires connected.  I used two rolls of steel wire on that coil and the point where the two connected has always a trouble spot in the back of my mind. This is the second time I have had this happen on a NS coil.  I will never again use multiple pieces of wire in a NS coil again.  I may do a video of a coil dissection on this coil so that we can all see what the inner wires look like after well over 100 days of constant running.
  I just finished a new NS coil, it is very large and uses about 10 pounds of 16# wire.  I used continuous wires with no connections.  It is an amazing coil and works really well. I will feature it in a video soon.
I have also been doing a lot of non galvanic tests.  I have had some really encouraging results.
Test 1:
I have wound coils with copper cores and copper wires no iron wire at all.  I have found that it is possible to get voltage and mA simply using copper alone.  You need to use dissimilar diameter copper wires.  This effect works in the ground and out of the ground.
Test 2:
I have also found that a NS coil works using enamel covered copper wire and iron wire in a dry state.  I will admit that I am now very interested in building a Faraday cage to do further tests with this non galvanic NS coil.
Test 3:
On a slightly different track I also made a replication of Daniel McFarland Cook's coils and got them working in a super efficient motor design.  I ran the motor for over ten days on discharged super capacitors alone.  I then dead shorted the capacitors for over 24 hours and started the motor run test again.  It started running with the capacitors showing 12 millivolts while under load running the motor.  After another couple days the motor was still running at the same millivolt levels.  I think this is working on the self charge effect these large capacitors seem to display.  I know that it will work very well connected to a regular NS coil.  NS coils behave very much like super capacitors.
I really need to make some new videos showing and better explaining some of these effects.  I will build a Faraday cage and do more tests.
Rosemary Ainslie
LASER - What a shame.  PLEASE CHECK HOW MUCH WATER IS THERE IN YOUR COIL.  And can you unwrap it under video?  Be most interested.
But REALLY WELL DONE for this.  And I look forward to seeing more.  Strangely I've now got the 'feet' to that coil - but LOL - have lost the coil itself.  I'm hoping to find it on campus.
Thanks very much Laser for your test.  AND Please keep us posted on your new developments.
Kindest regards,
Rosemary
