Self-Runner NS Coil Pulse Motor Live Video Stream. It's been going for months!
Started by lasersaber, September 01, 2010, 09:59:28 PM
lasersaber
I should point out that about half the coil is still working and I can run the motor off the working half using only one reed switch.  It's just has about half it's previous performance.
I am looking forward to taking it apart on video.
IotaYodi
Excellent work Laser. Im glad to see you coupled the cook coil to it. Electricme coupled his Jt to his small coil and lit up the led. Even though you used a splice you wound the coil correctly. Nice and uniform with the layers on top of each other. Makes for a nice uniform field and less eddy currents. The way its wound and the materiel's used makes a difference.
We do need to make these coils bigger but money is usually the enemy. If Pirate ever gets one going with his excellent earth battery setup we may see more advances.
What I know I know!
Its what I don't know that's a problem!
lasersaber
Rosemary Ainslie
Quote from: lasersaber on November 01, 2010, 02:38:05 PM
Dissecting a NS coil after 165 days of operation.
http://www.youtube.com/watch?v=nRSZcQ5cGAQ
Hi laser.  That was a really interesting autopsy.  Delighted to see where your new tests are going.  Please do keep us updated.  And very well done for all that construct.  It was utterly intriguing.
Regards,
Rosemary
shylo
Hi all,.... galvanic reaction ...was mentioned quite a bit....during this test....I noticed in the tests' I preformed that regardless of the amount of copper ,cotton ,steel or aluminum wire..........I could never get better than .75 volts/cell.....I made over 75 different cells...all of different sizes ,different amounts of copper ,different amounts of cotton.....the best arrangement I could get was six cells in series, paralled in sets of three....I still have six leds running non stop for over a month now ...all I have to do is mist them 3 times a day..their not in the dirt just lying on a dinner plate just using tap water ....how long before the metals rust out and quit?...I don't really believe in electron flow ...more so chemical transformation.......and I believe magnetism.....directs the flow of transformation.........voltage rise and voltage drop don't work on these cells I have.............magnetism can direct the flow of tranformation,...transformation should be able to direct the flow of magnetism.something to think about ....shylo
