Self-Runner NS Coil Pulse Motor Live Video Stream. It's been going for months!
Started by lasersaber, September 01, 2010, 09:59:28 PM
0 Members and 28 Guests are viewing this topic.
lasersaber
@ GroundLoop
I love your drawing of the Stubblefield coil.  I did take the liberty to make some modifications to represent the way my own coil is functioning.  First off, all my wires are exiting on the same end of the coil (this is also how it is pictured in the patent).  Secondly, while I did put a secondary on the coil in the begining, I soon unwound it and I never did use it to power the pulse motor.  My motor has always been powered by the primary windings themselves.  Third, as has been mentioned earlier, the coil is running dry.  I did origionally wet it in salt water, but since then I have not added any water at all.  It's been 75 days now running dry, though I am sure that air humidity is maintaining a low level of moisture in the coil.
BTW, this is what I meant when I used the term "self-runner" - that it is currently running on it's own without active input.  It still remains to be seen how long it will run like that.  Again, I do not claim that this is OU.  Personally, I do believe a certain amount of galvanic action is taking place, but I still find it fascinating that the coil is able to run for so long without having to add moisture.  I am not trying to prove anything or to win any prize - it's just my hobby which I am sharing with others who find it interesting.
Bob Smith
Quote from Groundloop:
QuoteThe Copper and Iron together with water forms a galvanic battery.
But we also have a coil and a core so if we short circuit the coil
for a short time then we can use the changing magnetic field to
run a magnet/rotor. An insulated pickup coil can be added on the
outside of the coil for various purposes.
@Lasersaber - great work!
Thanks GL for the visual - very helpful.
Would it be reasonable to propose that a properly wound pickup coil might be driven to resonance?
I'm thinking about Gerry Vassilatos' account of Stubblefield heating his cabin with 2 polished metal plates - presumably drawing on SEB technology - and wondering if resonance could be a key factor here.  By driving the pickup coils to resonance, if only in brief pulses, is it possible that a kind of access point to the aether's inpouring of energy is actualized.  I believe it could account for the heating of plates and much more.
Edit: clarification added.
Rosemary Ainslie
Hi lasersaber
I see in your videos that there's early evidence of current and voltage in the windings without any water at all.  Have you tried this - ever - without using any water on the coil?
Regards,
Rosemary
lasersaber
@Rosemary
I have tested voltage on brand new, unwet coils, but I don't remember the exact results.  I'm currently winding some more minicoils for my latest project.  I'll test one of them dry before wetting it down at all.  I'll post any results when I have them.
Rosemary Ainslie
Quote from: lasersaber on September 06, 2010, 09:11:52 AM
@Rosemary
Many thanks
Rosemary
