Self-Runner NS Coil Pulse Motor Live Video Stream. It's been going for months!
Started by lasersaber, September 01, 2010, 09:59:28 PM
Pirate88179
Here are some photos of my crude attempts at this from a while ago.  As I have said, we all did learn a few things and, yes my coil, seen here with one layer of windings only, did have an output after building and before placing in the ground, when it was totally dry.
So to answer a few questions asked of me here, yes, the 2 metals are totally insulated from each other and yes there was a dry output, although not as much as after I wet it and let it dry.  No other electrolyte was added.
Lasersaber put it best and it basically summed up our understanding of this coil from back then in that it is partially some sort of galvanic reaction and also it is something else.  Otherwise, if galvanic was all this ever was, why would NS's coils not break down after years in the ground?  Maybe it is a very, very efficient type of controlled galvanic reaction?  I do not really know and do not claim to know.
The 2nd and 3rd photos are of my larger coil which actually has 2 layers of primary such that all the wire ends can be on the same end as NS has done it and now Lasersaber.  The max. mA's output from this small coil was 47.2.  The core was a galvanized iron spike that had very strong attraction to my test neos in the store.
I hope this answers those questions asked of me but, I am telling you that Lasersaber is setting the pace here and is far beyond what our group was able to do.  My suggestion is that for those that see this as I, and many others do, keep following and try replicating.  For those who think it is nothing new and not worthy of messing with....then don't.
yaz
The secret is in the rust.
When I was searching for iron oxide, I came across a page that said that iron oxide is like miniature diodes. A crystal diode inside a crystal radio works without any batteries or galvanic cells. Maybe that's what's happening when the coil dries out? It converts ambient rf  along with the back emf from the coil and it keeps on running.
A crystal radio works better with a good ground rod, maybe try grounding out a coil or ? and see if it improves.
Better yet check out this page:
http://home.earthlink.net/~lenyr/ntype-nr.htm
He used galvanized iron wire and ALUMINUM wire and made a NEGATIVE RESISTOR.
Someone else made a negative resistor by heating up galvanized sheet metal till it turned black and those little black spots had negative resistor characteristics.
Maybe wind a galvanized steel wire and copper coil and heat them both with a propane torch till they have brown/black oxides on them and see if it runs any better/longer. I would definitely try the galvanized wire and aluminum coil for sure.
See page 25 on this homemade diode pdf, it says that steel corrosion (rust) is a negative resistor....hmmmm
(This pdf file is 3.9M long, I would post a snapshot of the page but don't know how)
http://softsolder.files.wordpress.com/2009/01/diy-diodes-nisley.pdf
Lasersaber, damm good work man! You're definitely on to something there!
lasersaber
Yaz,
Great post!  This gives me a lot to look into and some new ideas for experiments.  I really appreciate your input.
nievesoliveras
What I usually do with a bad post is I just ignore it and the person goes away.
If you get involved it is like putting logs on a dying fire.
Post only things that help the topic like graphics or photos, even a schematic.
The person will see that you support the topic without getting involved with the person on a long discussion that apports nothing to the cause.
For me this died here.  I just want to get the energy problem solved.
Jesus
powercat
Hi lasersaber
I watched all your five videos on how to make the coil, very well presented and easy to follow.
Have you ever tried running 2 magnet rotors one at each end of the coil, if this was to work would you find that the rotors rotate in opposite directions to each other ? only a thought.
The little baby coil you made is looking great and performing very well for its size compared to the big one
all the best
cat
