pat. 3469130 Jines, J.E. Magnetic Motor, does it work?
Started by tbird, September 03, 2010, 08:19:17 AM
tbird
hi all,
about the attachment....
can the spring (4) be adjusted to move the shield (3) so it uncovers the stationary magnet (2) in the top figure (starting between the 2 magnets & ending as in the bottom figure), but only require little effort to move it back over the stationary magnet (2)?
tom
It's better to be thought a fool than to open your mouth and prove it!
tbird
ok, maybe that was so easy , it was hard.  let's have a look at it a little different.
assuming the shield assy is as far right as possible, with the only influence on the shields being the magnetic pull of the magnets, where will the shield assy want to go, from the shown position, naturally?
1. nowhere
2. to the left (covering left stationary magnet)
3. center between magnets
tom
tbird
hi all,
since no one feels one way or the other, let's assume the shield wants to go between the magnets and the spring can just overcome this action enough to move the shield out to a point the magnet is uncovered.
let's add the lever arm to the simplest form (see att).
any thoughts?
tom
wings
Quote from: tbird on November 28, 2010, 11:11:30 AM
hi all,
any thoughts?
tom
I try ???
the magnetic field acts as a potential field, then except for the losses due to hysteresis that you enter can be returned.
you can draw a spring or a cam that balances the force of attraction or repulsion at any point of rotation.
energy balance has to be done on the friction and hysteresis losses
tbird
Quoteyou can draw a spring or a cam that balances the force of attraction or repulsion at any point of rotation.
does that mean you think the shield can be moved in and out (on the linear bearing) with little effort if the spring is adjusted correctly?
tom
