Homopolar Stack (multiple generators on one common shaft) Brent Hasty
Started by teknomage2012, September 05, 2010, 03:44:21 PM
teknomage2012
Time to flare up this topic and enlist the global community to help further my experiments by open sourcing them, as we need a Over Unity Device made available on ebay to shut up the nay sayers and force industry and science to move on to the next chapter in the pages and annals of history and civilization.
I became aware of the homo-polar generator about 2001.  By 2004 I had researched, postulated, then constructed coarse experiments to verify my insights into the homo-polar generator.  Based on the results further experiments into the marketable design of a functioning overunity homopolar generator have been postulated and experimented with by me and a couple colleagues. The results are promising.
Now, I am not here to sell snake oil, I am here to see progress! The economics of life have dampened the research and development progress of my experiments. I therefore enlist the thinkers and tinkerers around the globe to peruse third party verification, and to a much greater extent to fire up thier own small shops and to manufacture and flood the online markets with functioning devices.
I will no longer hold my cards close to the vest, protecting any intellectual rights or ego of discovery. I would rather be able to just buy one at wallmart so here goes.....
My next post will include what I have on hand to offer in the spirit of open source, that we may all participate in our open source future civilization.  Because eventually we must leave this solar system or become extinct, so no time like the present to start....
Brent Hasty
www.hasty-solutions.com
teknomage2012
Now begins the GPL Open Source posting of the best information I have on hand from my research, theory, and experiments into building a marketable homopolar generator that will yield some level of easily measurable overunity output.
I will attach a couple blueprints that should make replicating simple. I only require (request) all resultant discoveries, and improvements built upon and in addition to, be likewise added to the public knowledge base in the spirit of GPL Open Source evolution. As the worlds need this day, yesterday and tomorrow are too great to worry about patent capitalization. If any have the the ability for minor or mass production, it is highly encouraged; I would smile to just see the market flooded by this or any other functional zero point energy generator.
The first key of the homopolar generator I found through experiments is:
      For the same Axial Magnetic Orientation the flow of DC Current Reverses with a reversal in the Direction of Rotation, clock wise + rim - axle --- counter clock wise - rim + axle.
Second key of the homopolar generator I found through experiments is:
       If two or more homopolar generators are placed on a non conductive common shaft and electrically wired in series, with their magnetic axises in opposition (that is north to north or south to south or N/S S/N N/S S/N etc....) The sum of the output voltage will be the additive of each of the individual homopolar generators on the common shaft. In this manner it would be possible to build a homopolar generator with a 14 VDC output that would feed a plethora of common off the shelf electric appliances, including a grid tie inverter, hence anything.
        I will coin a phrase to describe this as a Homopolar-Stack
Third key of the homopolar generator I found through experiments is:
       When placing a even number of opposing homopolar generators on a non conductive common shaft, intelligent design can yield a center positive on one end and a center negative on the other end of the shaft. This will allow for the elimination of the rim or peripheral pickup brush and an enormous amount of drag, by allowing stationery pickup brush to be located in the center point of rotation with the least Feet Per Minuit of rotary contact.
Forth key of the homopolar generator I found through experiments is:
        Two or more independent homopolar-stacks can be wired in series or parallel to multiply the power as needed.
Fifth key of the homopolar generator I found through experiments is:
        Multiple spiral slots cut in the copper discs by laser/plasma can induce a complementary electromagnetic field to that of the permanent magnet during discharge of the homopolar stack, further increasing output when oriented intelligently to the magnetic axis and direction or rotation of each of the stacks sub homopolar generators.
Sixth key of the homopolar generator I found through experiments is:
        Support it on a magnetic bearing in an evacuated bottle to reduce parasitic losses.
Seventh key of the homopolar generator I found through experiments is:
         In a homopolar stack to maximize output and minimize eddy currents it is important to circumferentially provide a complete conduction path from one generator to the other on the periphery and near the center point around the axle.
Yet to determine:
First:
      what effect does the opposing spacing of the homopolar stack have on output.
              example      -n/s-----------s/n-   or -n/s--s/n-
      If greater spacing improves output then
              what is the effect of a diamagnetic material (such as bismuth or Bucky ball carbon) separating the individual homopolar generators on a homopolar stack?
Build one for yourself, build them for your neighbors, ant there neighbors....
Brent Hasty
ps.... more to come..... looking forward to everyones participation and feedback.
altair
Hi teknomage,
thanks for sharing your experiments. This is very interesting.
Could you give us an idea of the dimensions of the pictured stack ?
Have you really been doing the experiments at VHRPMs of 20K-50K , or at slower (more reasonable & less scary) speeds ? :D
I also wonder about the behavior of mercury contacts at those speeds...
I will have to review the theory on the homopolar generator before continuing, to understand fully the principle.
Keep adding to this thread, please.
P.S.  Maybe hypercom should repost his message here, for completeness. He too is onto something big.
gravityblock
Brent,
I noticed on your drawing it says patent pending.  I have released many drawings on this forum, using N/N or S/S configurations to increase the voltage and to extract the current from both sides of the axis.  This is nothing new.  In fact, I have hammered this idea on this forum over the last few years.  You could even go brushless by using multiple halbach arrays with this concept.  I don't know why I'm telling you this, for you will probably try to patent the brushless concept also.
GB
teknomage2012
This was designed around 3.5x.5" neodymium ring magnets, to be fitted inside 4" PVC tube where it could be sealed and evacuated.
The current rendition of the brush mechanism is having the + and the - ends of the rotor shaft slightly concave followed by a 1" diameter brass ball then another concave cap that is lightly spring loaded. Forming a contact from rotor to stationery housing whose point of contact is self centered in the axis of rotation. Looking something like    (0)
Yes, experiments to date have been at lower rpms in the 4 digit range, most research has been in the direction of making a device of useful voltage having reduced drag with a lesser focus on amperage. As speeds have gone up we have had some success taming vibration by machining a groove on each end of the rotor rim and encapsulating some free moving ceramic balls to act as a self balancing mechanism.
In the evacuated chamber we have introduced a rarefied amount of argon, whose molecules are centrifugally compressed by the rotor to the housings cylinder wall. In the wall is a pathway to allow the molecules to escape in a loop where they are reintroduced to the chamber about the brass ball in the zone of lowest pressure. They are then drawn into a hollow rotor shaft through ports in the concave cap. The hollow rotor shaft has along its length holes to allow the molecules to exit into the spiral slots in the copper disks. From there they are flung out of the rotor and compressed against the housing wall..... The loop repeats.
The rarefied argon serves to aid the rotor in heat removal for sustained higher power draws.
In future iterations we believe the brass ball can be removed and the rotor free floated on a halbach array with only a spark gap between the rotor and the housing. The focused molecules of argon spiraling into the shaft would then be excited with a high voltage/frequency start circuit to arc the spark gap and initiate a plasma state contact to the rotor to draw power.
Brent Hasty
Quote from: altair on September 06, 2010, 08:55:52 PM
Hi teknomage,
