Crystal Power CeLL by John Hutchison
Started by dani, April 26, 2006, 04:11:36 PM
NickZ
  There may be a few people just lurking in the background, waiting for the right moment to get involved. This thread is complicated and getting long, not all can deal with the experimental side of things, and would like to just see some result first.
  There is a lot of action being done in the Energetic Forum, under the  Earth Light Thread, though. Many different ideas are being tried, the latest direction is the work on the semiconductor cells, and the making of multi-cells or multiple cells to raise the voltage levels.
jbignes5
Yes Nick I am aware of the thread at EF. The problem there is I have no access. Mostly because I couldn't stop myself from giving my opinion about a rather public battle on there. The problem is some people like to lay claim to things because they mod one little part of the system. This I took exception to. It has always been touted that EF was an open source en-devour. The problem is that people didn't invent the stuff we are using. Yes they thought of new ways to put them together but much as everyone is learning life itself draws from this energy. The matter we intake facilitates the potential differences that we need to organize and use this energy to our ends. They did not invent that. We are merely discovering these materials out. We are not inventing them. They are not doing anything that they were not naturally designed to do.
I would appreciate it if you guys expanded your forums reach and participated here as well. Seeing that the EF forum is only about making money I thought we would gather in many places ensuring this stays public information. You guys know that Aaron owns that board. There is nothing Open Source about that. He can do the same to you as he has to me and restricted access to me because I called him out on a few things. Although those posts got deleted they were valid and I stand by them.
So please talk to the EF experimenters and ask them to move or copy the information to this thread or even start a new one dedicated to the whole story about these batteries. I for one would like to participate but I don't see any action on this forum when compared to the EF.
jbignes5
 So back to the crystals. Just like in liquid crystals we have movement or a lining up of the structure via the polarization. As the heat leaves the structures become rigid or condensed. Think of heat like this: greasy balls of charge. Charges are very mobile units of crystalline fury. Kinda like a mobius loop. These highly dynamic swirls of crystals is the flow we see in water and all liquids. And to tell you the truth it's mass is so dense that no one could fathom it. Mass is a weird thing at those scales. All real mass is in motion in some respect. Either it is moving from point a to point b or it is spinning around it's axis. These particles are always in motion even when not moving from point a to b. This is where we get into the web like structure that forms around points of motion or potential. Think of the real matter at this point. They line up according to their structural geometry. Edges, surfaces and points tend to line up via induction. You must understand even at those small scales that they are floating in a fluid like substance. So this means eddies and flow patterns from the previous particle to pass that specific point left swirls and flows in the fluid. Thes particles also have real mass. They displace the medium in which they flow. They are hydrophobic in a sense of the medium they reside in.
On our scale this would parallel the body under deep water. I wonder if there is a water simulator we could test the shapes with. This simulator would need the static rules as well for flow charge and surface charges as they flow.
jbignes5
 One avenue I am going to look into is the compression of the crystalline structure as it forms. I am thinking this is the technique which would increase the density of these "batteries" or Valves as I like to call them. The round version, inside of a tube is much better. This allows a natural Tension to build up inside of the crystal structure. As the material phase changes with heat it acts much like water does as it goes to ice phase. This causes a smaller layer of crystalline matterial and the density changes as the crystal forms in the interior. Higher density means more push power. So this compresses the exterior crystals into the tubing causing a pumping action to happen in one direction only. I would think someone should look into what crystal they use in electric lighters. You know the ones they snap a crystal and it conducts one way. Some of those put out 1k volts sometimes 2k.
Maybe we should look into this: Polyvinylidene fluoride
jbignes5
After reading up on this I think I have figured out what those very small transformers are doing. http://en.wikipedia.org/wiki/Polyvinylidene_fluoride . One of the uses of this material is to cover 30 gauge and lower wires. It's piezo electric. From resonating the coil we can get additional potential from this covering. As the wires vibrate they impart a higher voltage. This is merely a static boost with very little current. Once the flow is established the static potential raises for seemingly free.
I think the magic in making these cells is to include compression of the crystal lattice as it grows. The more structural content the crystals have the better the capability to be additive to the total potential. These crystals should resonate based on geometry and compression forces, all from the noise of the Universe. Once you take away the compression aspect it ruins the process.
I'm thinking the shape is very very important. It must be an enclosed unit that can sustain huge pressures.
