Crystal Power CeLL by John Hutchison
Started by dani, April 26, 2006, 04:11:36 PM
Drannom
hello
Hutchinson had begun experiment after use a military diode !
if someone can find one of those diodes it may solve a part of the mystery
anyway, i think that crystal cell have been already give in the electrinium.pdf document
it explain how easy we can do it with steel (carbon-iron)
and more dificult with silver-iron compound,
a single molecule give 7 volts, so it do not need to be crystallize at all, imagine a plate
Master in alum pyramid growing crystals at http://youtube.com/user/Cristallerie
ian middleton
G'day all,
@Koen:  Nice attempt at a recovery with the quirk there dude. ;D  If the quirk moves that much, just put it in a hamster wheel
and generate volts that way .  ;D ;D ;D
Any chance of posting the formula for this stuff ? I haven't got any Germanium so I'll substitue it with pyrites.
Gallium to aluminium is like termites to wood. ;)
I mixed the contents of the cell I busted open yesterday with the gallium/aluminium powder I made a couple of weeks ago. I knew I'd find a use for it. Not wanting to be outdone in the naming stakes I'll call it Galluminium. ;D ;D
This new mix, which was a fine crumbly, damp tea leaf consistancy was rammed into a plastic tube with the original copper electrode down one side and a stainless steel strip down the other. The stainless becomes the -ve and copper +ve.
It is sitting  at 0.52V and has no trouble supplying 160uA.
I have this new compressed cell in series with the washing powder cell, total 1.213V and they are happily running a digital watch.
Still nothing to get excited about, but novalty value nonetheless.
Quirk to Enterprise, beam me up Scotty  ;D ;D
Ya gotta luv this
Ian
Koen1
Hi guys! :)
@Drannom: Well, the electrinium thing is not as easy and clear cut as it seems.
It sounds easy, but try to imagine how you are going to seal a compound of two metals
like gold and silver inside a third metal while keeping the dipolar orientation of all the
compound molecules exactly the same, and I think you'll find it's almost impossible
to do so. Or at least, that's the impression I get when I think about it.
If you have any idea how to do that in the home workshop, then I'd very much like
to hear your suggestions. :)
Besides that, the electrimium "patent" does not give very clear indications on what
materials can be used. A few are suggested, but it is very clearly stated that atoms
must be chosen with suitable frequencies and there is zero explanation on what
exactly the author meant by that. It would seem the author had some kind of idea
in mind that every atom has its own specific frequency, and somehow the interaction
of these frequencies would "pump" electrons through the material. But how exactly
is not explained at all, and what frequencies he is talking about is also not explained.
Is he talking about nuclear magnetic resonance frequencies? Or about electron orbit
and emission frequencies?
How does he want to keep a Au-Ag pair in its place and with the right atom on the
right side of this pair, and in alignment with all the surrounding pairs, and at the
same time pour molten iron over the lot to cast them in it? I think even if you managed
to put the atom pairs on a surface with all the Ag facing one way and all the Au the other,
as soon as you start pouring the molten iron the entire placement and orientation will be lost
and you'll end up with a pool of molten iron-gold-silver alloy with none of the Au-Ag pairs
as you intended them.
At least, that's what I think...
@Ian
Quote from: ian middleton on May 27, 2008, 08:58:56 AM
Mwahahaha :D yeah good idea ;D
QuoteAny chance of posting the formula for this stuff ? I haven't got any Germanium so I'll substitue it with pyrites.
Yup, sure is.
Formula was roughly: 1/5th of a tubes volume of silicate mix, mostly (homemade) sodium silicate (nicely made this time,
nice and white powdery material) with about a teaspoon or two of silver sand, about an entire tubes volume of RS,
a teaspoon or two of water, two teaspoons of gallium, one and a half teaspoon of germanium powder, a pinch of
aluminium powder. Tube is approximately 13cm tall and 5cm in diameter, so volume is 1021,15 cm^3.
I added the extra silver sand for two reasons: additional pure quartz and to compensate for any possible superfluous
sodium hydroxide leftover in the homemade sodium silicate; for this last reason I also added the pinch of aluminium
powder (after all, if there was any leftover NaOH it should react with the Al and neutralise the mix).
Heated it for a few hours while stirring well. Heated it for a couple of hours a few days later again. And again after
it had crawled out the tube. And again after that. And again. And again for the last time yesterday.
Don't know if it will work without the germanium though, but it might. ;)
QuoteI mixed the contents of the cell I busted open yesterday with the gallium/aluminium powder I made a couple of weeks ago. I knew I'd find a use for it. Not wanting to be outdone in the naming stakes I'll call it Galluminium. ;D ;D
Galluminium it is, sir! So noted and recorded. ;D
Quote from: Wikipedia:GalluminiumGalluminium (G?ljəˈmɪniəm) is a silvery white and ductile member of the boron group of chemical element alloys. It has the symbol GaAl; its atomic number is 13/31. It is not soluble in water under normal circumstances. It does not occur naturally. This material was made famous by the genious alchemist Sir Ian Middleton of Australia, who first made the material in 2008 for use in the then radical and now common crystal energy cells that power everything.
It has been rumoured to be distantly related to the infamous Quirk material that caused the global blackout of 2012 and has been shrouded in mystery ever since.
:D ;D
QuoteThis new mix, which was a fine crumbly, damp tea leaf consistancy was rammed into a plastic tube with the original copper electrode down one side and a stainless steel strip down the other. The stainless becomes the -ve and copper +ve.
I like your scientific terminology there. "was rammed into a tube". ;D
QuoteIt is sitting  at 0.52V and has no trouble supplying 160uA.
Yes, if the output remains. I thought you said you're pretty sure the washing powder
cell is galvanic? But the Galluminium mix cell is interesting... certainly! :)
QuoteQuirk to Enterprise, beam me up Scotty  ;D ;D
Bwhahahahahaha lol rofl etc :D :D
Ya gotta luv this[/quote]
Luvin it I tell ya! ;D
ian middleton
G'day all ( again)
@Koen:  Boy you're on form tonight  ;D I just let one of the guys here at work read your wikipedia quote, now he's gone of to google it! ;D ;D ;D. Brilliant!.
Thanks for the mix details, and I like the idea of the pinch of Al to neutralize any NaOH. :) I was going to ask you if you knew th pH
of the quirk but it looks like you had that covered. ;)
Ok back to work
Make it so number 1  ;D ;D
Ian
jeanna
Some archeological notes from the kitchen of the Enterprise, probably dating to sometime in 2008:
I made a mix hoping I could incorporate both Al and Mg in the crystal structure. Possibly as zeolite.
The mix:
1Tablespoon   dry clay
1 teaspoon     Epsom Salt (Mg sulphate)
1 teaspoon     Na Carbonate (washing soda)
1 Cup            dry portland cement - contains or is clinker
1 Cup            dry sand (this was used for Trawiger pyramid and contains some small amount of NaCl)
1 Cup            water
This mixed easily and it appeared that the clay dissolved first, then the sand dissolved. The whole thing became a very thick soup that had a gritty sound to it but was very homogeneous.
Since I wanted to use the Al and Mg of the metals to make an e-crystal, I wanted to keep to the Al for the container. This presents an interesting problem.
Melting container.
I am not sure adding Al powder would be enough? but it is a good idea. I don't know where to get Al powder yet.
After a day of taking readings I found this patent:
http://www.pat2pdf.org/pat2pdf/foo.pl?number=6042808
This patent is for a manufacturing process for making zeloite at normal temperatures and includes the Mg which is why I looked for it and it also includes Ga. It has pictures and some formulas. Have a look.
Back to my kitchen.
I have taken a pic of a few things. Hopefully I can get it into one post.
The bottom of the Al juice can is filled with this stuff then I cut the can some more and made the spiral electrode that is inside. It only took 30 minutes to be able to place this electrode into the soup and have it not rest on the bottom. It solidified a room temperature in 2 hours and this morning after 18-20 hours, it has become the white of dry cement.
If I touch one probe directly to the crystal and leave one on the electrode I read 1 volt and 124uA. But I think that is because the probe metal is nickel or zinc plate, so I don't count that.
The pic shows the leads on different Al probes. I stuck 2 Al wires into it as well as the can strip, but the terminals are all made of Al.
Later I lined a cheese tub with Al foil and filled it and added a foil electrode and an Al wire electrode.
See how the foil has torn from the crystal? It dissolved it and I assume made some H2 overnight. (too slow for a car  ;D )  So, I am wondering if I even have any real surface contact between the Al foil, wire, can and the crystal.
Outside the pic are 4 pancakes that have dissolved their Al foil plates - and their foil electrodes too.
Maybe when it is all dry, I will use some sodium silicate to "glue" the electrodes into their places. Perhaps this will give some avenue for the charge to travel.
here is the pic I hope.
jeanna
I forgot to add the can gets 0.119vdc and 2.9uA using both Al terminals as shown in the pic.
