Crystal Power CeLL by John Hutchison
Started by dani, April 26, 2006, 04:11:36 PM
jeff0516161
I just want to say that I've never mentioned electrinium once. Yes, I pointed to the theory, however let me STRESS the use of the word.. "point".
I was trying to "point" you all to "something" you all should pay attention to.
I'm not here to show pics, videos or anything. Even if I did, it would be surely disregarded by you anyways. Like I said, I'm not here to prove anything.
The last thing I would like to say....
We all knew Tesla created wireless power transmission through radio. You all are trying to create a crystal battery and obviously seeing "some" results...where do you really think this energy originates from? That itself is what you need to focus on. Your battery you create, if successful, will not actually be a "battery".
I forget who on this thread said they were going to urinate in their mix.... I don't know why or how you came up w/ that idea, but actually was the smartest thing I've read here.
ian middleton
G'day all
@jeff0516161
As far as the electrinium theory goes, it has been read and re-read a dozen times. Logically it doesn't add up, period.
As for the urine, well I have to take the blame for that one.
I am not dissagreeing with you when it come to the energies or their origin with regard to the crystal battery or crystal converter as it is sometimes known. We all know it converts something.
We also know that there is a connection between the works of Tesla, Stubblefield and Antonio Meucci all of which can be applied to a crystal battery/converter.
Granted a true converter is not a battery but to all intents and purposes it will still be regarded as one because that is what these things are being designed to replace.
Now whether the primary energy comes from a central sun ( in my view, doubtful) or cosmic rays or orgone or ZPE itself
is really not important. Does a Samoan fisherman ponder the production process of his fishing line? No, just so long as it catches fish. And he has a pretty good idea of what he wants to catch.
Also anything you do contribute to this thread will be looked at and evaluated.  You will also be given the courtesy  of a reply. We do not blindly disregard anything.
Kind regards
Ian
nightlife
Hi Ian, that is a nice collection you have there. Does any of them have Tourmaline in them and or have you tested any Tourmaline crystals to see if they indeed do contain electricity?
It is said that a small pieces were found to hold 0.05 volts of electricity and I still have not been able to get my hands on a piece to verify that.
It was also said that it never looses that electricity unless it is heated to 1000 degrees or higher.
I stated another thread about it but I have not received any reply?s.
Pirate88179
Nightlife:
Back in my old geology major study days I learned that tourmaline will generate electricity when heated.  So, I guess
it is not generating it, only converting heat to electricity.  Kind of like the pizo effect which converts compression energy into electricity.
Years later, one thing we found out (by accident, of course) when machining large pizo disks in our ceramic machine shop, we used to hold them down using a precision wax which was heated and then bonded to precise ground steel machining plates.  This was fine.....until....we found that heating the pizo material built up a huge (like 13,000 volts or more) charge in the material.  IF discharged on the hotplate, which really hurt, and then allowed to cool, we found out (guess how?) that it built up a similar charge when cool IF discharged when hot.  The temperatures used were only about 180 F.  This reminded me of what I learned about tourmaline.  Pizo was not supposed to do this, but it did....trust me.  I had an arc jump about 5" from the hotplate to my upper thigh while heating.  And then, once cooled and discharged (or so I thought) I got zapped again when handling.  If pizo shares this ability with tourmaline, I wonder if tourmaline will create electricity when compressed like pizo?  Never tried it. Electricity is all around us.
AbbaRue
I read somewhere a while back that the amount of energy bombarding our planet from space
could light 200,000  100W light bulbs for every man woman and child on our planet.
So far the only real tried and tested device we have to tap into some of that energy is the solar cell.
We know that piezoelectric devices convert vibration into electricity (record player needles and BBQ lighters).
One theory I have pondered ever since first watching John Hutchison's battery at work:
If a piezoelectric crystal was made the proper size and connected right it could vibrate from extremely high frequencies.
Instead of vibrating from sound waves or groves in a record.
What it would need is some form of antenna to collect the vibrations and transfer them to the crystals.
Many different sized crystals could be combined to collect a large section of the spectrum,
My theory is that this is how the Hutchison crystal cell really works.
The metallic components act as antennas to vibrate the crystals and as wires to convey the energy to the outside world.
Di-electric components act as capacitors to form oscillations and filter out the DC from the AC.
So if we contemplate these possibilities when constructing our cells, and move away from galvanic concepts we may get a working model.
John mentioned building a cell from Barium Titanate alone, has anyone ordered some and tried building one.
Barium Titanate is much cheaper to buy then Pure Germanium.
I seen a company in the USA that sells it.  Reade Advanced Materials.
John said the unit he built gave him a 1000V shock when he picked it up wrongly.
I would try to order some myself but I don't know how easy it would be to get it across the border into Canada.
Anyway this may be a place to start.  Barium Titanate is a very good piezoelectric material.
Also a very good Di-electric, it is the main ingredient in the new Super Capacitor they plan on using to run electric cars.
Just though I would post this so others may know were I'm coming from when I say I believe the crystal battery is a true science.
Another thought, even as our earth circles the sun we undergo small changes in gravitational force, which could vibrate crystals too.
I believe this is why T.T. Brown found that very dense materials like granite and basalt produced electricity. (Petroelectric effect)
