Crystal Power CeLL by John Hutchison
Started by dani, April 26, 2006, 04:11:36 PM
nitinnun
the more metal surface area i have, the more amperage.
because more surface area means more "ZPE molecules", arranged in parallel:
nitinnun
the rochell is oxygen, hydrogen, sodium, and potassium.
it is chemically similar to sugar and table salt !
pyrite would provide the iron atoms. like my cells have iron on them.
galena has lead. lead is diamagnetic, like the copper in my cells is diamagnetic.
(bismuth works better than copper or lead. and bismuth is more diamagnetic than both !)
there you have it. the wonder hutch gets the metal atoms from pyrite and galena.
the rest is about how those atoms form covalent bond chains, to connect between the metals.
john hutchison polarizes the molecules towards the 2 terminals, when he charges them with electricity.
so that the atoms are spitting their magnetism towards the terminals, when the middle substance dries.
Koen1
Right...
Now don't take this the wrong way, but it sounds a bit oversimplistic...
"there you have it"?
All we have there is a couple of suggestive remarks that point out
what you deem to be clear similarities between certain elements
used in the cell materials that Hutch and yourself used in their
completely different cell types. We get zero explanation or underlying
theory to explain anything even regarding those elements.
I hear you say that you think Rochelle Salt, sodium potassium tartrate,
is chemically similar to sugar and table salt because the compounds
consists of H, Na, K and O... But it's only the constituent atoms that
are the same, the chemical structure and crystal structures are totally
different...
I hear you say that your glue cell has iron and copper,
and pyrite and galena contain iron and lead,
and that's about all you said. Yes, so what? That doesn't really explain
anything...
Oh, right, and a suggestion that the metal atoms "spit their magnetism
towards the terminals", whatever that means.
This may be a clear description and explanation of things in your mind,
but it is in fact quite a vague collection of remarks;
can you please try to rephrase it into a more coherent line of thought,
where you clearly indicate how you think that works?
And it's ok if you can't, but then please say so, because now it sounds
like you think you know exactly how it works but you're not making this
clear in what you posted, and I think we'd all like to at least try and
understand what in your mind appears to make so much sense.
So pretty please, can you give a bit more explanation there?
Thanks.
sutra
Hi guys,
I also tried the sugar option because is a piezoelectric substance but it didn't work....it cooks too easily and Rochelle S. is in any case much more piezo.....I really have to decide myself to use the HV DC...
@ Koen,
from 2001 to 2006 I've been in South Africa....
bye
DDarcade
Hello everyone I'm new,
So, I've been reading all your posts since you started.  I'm quite interested in new technologies to produce energy.  I built a small crystal cell, and I must say it really seems like a galvanic cell. When water is added it is a galvanic cell.  You might as well just have the copper dipped in the water, and the aluminum acting as the cathode.  Has anyone built a cell purely from dry material? Also, I bet when water is added it takes forever for all the water molecules to evaporate out of the cell. I'm going to try melting the galena, rochelle salt, silicon, pyrite(ground), and quartz. Then I'll pump it with a ton of electricity till it dries.  Has anyone done this? Also, I don't know what you guys think, but John Hutchison seems a little bit tricky at times.  I saw one video with him dangling a UFO toy from a string and claiming it was his Hutchison effect that was lifting the UFO.  Could he be possibly be faking these crystal cells to get publicity?  Also, does anyone know where the electrons come from when a magnet passes through an induction coil?  Do they come from the the copper itself (just being excited and thus breaking down the copper wire over time), or are the electrons coming from the surrounding environment?  If the answer is that they come from the surrounding environment, could you please show me a scientific published experiment supporting this hypothesis.  I really want to know the answer to this question with 100% certainty, because if magnets and semiconductors are truly acting as "electron pumps" then "free energy" may someday be reality.  Plus, this basically gives some clues to explaining a connection between electromagnetic energy, electricity and magnetism.
Thanks, Dustin
