Crystal Power CeLL by John Hutchison
Started by dani, April 26, 2006, 04:11:36 PM
0 Members and 28 Guests are viewing this topic.
mscoffman
Quote from: wintermuteai1 on March 22, 2010, 03:47:38 PM
Thanks Ian looking forward to hearing about your new results. One thing from reading the patents and info I posted, I think it bears looking into where it talks about using a rotating magnetic field, and It seems plausible that it may work on other materials such as everyone is trying in this thread, not just tourmaline. I found it interesting to note also that the resistance value of the "carrier" material needs to be less than the main ingredient. I propose if anyone can to decide per batch what your main ingredient might be and make sure the other materials as carrier has a smaller resistance than the main material.
I was reading the tourmaline blog and saw the rotating EMF details too.
I have question as to whether this impoves real outcomes or is just
a complexity added feature for patent purposes. Is sounds difficult
and expensive enough to do correctly. I like Ian's diverse materials
approach, first, better.
Have you ever cracked a full plastic frozen icecube tray in the dark?
There is a luminous flash of blue light that is atributable to either piezo
or static electricity..very impressive.
I thought the gemological file was interesting saying that retention
of static electric charge or lack thereof was once used to separate
real gemstones from paste. If you start with diamond which is carbon
therefore potentially conductive, then go down through gemstone
made under pressure and often containing metals.  This conductivity
method does not sound *too* very surprising.
:S:MarkSCoffman
ian middleton
G'day all,
Heres an update on a test I am currently running with my latest batch of cells.
I'm running very low on resources now so I've had to scale down the size of these things to make the ingredients go furthur.
So far I'm very pleased with their performance but alot more testing an observations have to made yet.
The thing to bare in mind is that these "minicells" only have a volume of 0.197 CC of matrix. They are small.
This next bit may seem a bit tedious and long winded but it will give you a good idea as to how these things perform. I will tabulate the latest results.
Cell from batch 21-2010.
Start           0.205v     @0.525mA  Load = AVO 8 set on 1mA range :    R=390 ohm
T+4  mins     0.211v     @0.540mA
T+9  mins     0.222v     @0.570mA
T+12mins      0.228v     @0.585mA
T+15mins      0.234v     @0.595mA
T+18mins      0.242v     @0.620mA
T+22mins      0.252v     @0.645mA
T+26mins      0.262v     @0.672mA
T+30mins      0.272v     @0.692mA      Temp   23.6 0C
T+35mins      0.279v     @0.718mA
T+39mins      0.287v     @0.739mA
T+42mins      0.293v     @0.752mA
T+45mins      0.297v     @0.765mA
T+49mins      0.302v     @0.775mA
T+55mins      0.307v     @0.791mA
T+60mins      0.310v     @0.800mA      Temp   23.7 0C
T+65mins      0.315v     @0.812mA      Temp   23.8 0C
T+70mins      0.317v     @0.815mA      Temp   23.9 0C
T+75mins      0.318v     @0.815mA
T+80mins      0.320v     @0.820mA
T+85mins      0.320v     @0.820mA      Temp   24.0 0C
T+90mins      0.318v     @0.818mA      Temp   23.9 0C
T+100mins     0.328v     @0.841mA      Temp   24.5 0C
T+110mins     0.324v     @0.840mA
T+115mins     0.325v     @0.841mA
T+2hours       0.325v     @0.841mA      Temp  25.0 0C
T+2hr10min    0.324v     @0.838mA
T+2hr35min    0.322v     @0.833mA
T+3hours       0.320v     @0.820mA      Temp   25.5 0C
Testing continues.
To reduce the likelihood of any galvanic reaction between pos and neg, the mix was made pH neutral 7 (well as close as you can get with a bunch of test strips).
As this cell matures I expect it to settle down to a slightly lower value over the next few days, we'll wait and see.
Catch you later
Ian
das aloda bullspit
the cell i made is not so good as i think
it was around .80 volts continuous it still is and the one at 6h volts is still fluctuating between 6h volts and0.10 volts its all gone shitshape for my cells mr ian middleton I see you have had more luck than me with your cells
May i ask what youv ingredients  used for your caco4 and portland cement cells did you sue anything else in yours? hve you thought of adding some germanium or niobium? i hade a good cell with some niobium in it but sadly i had t throw it  away as i needed room for new xperimnts  also are your mini cells use the same ingredients as the 2-2010 cells running the led ? in your previus photos? could you give me the details on what you used in yur latest cells please? it would be greatly appreciate as my cells..they are a not good enough.still cant figur out why cell 1 is 6h volts?
wintermuteai1
Hey Ian and all:
I have done much research and I believe that we are going about this in the wrong way.
It is my hypothesis that (as per T.T. Brown) these materials are actually collecting/converting radiant/zpe energy. I think that each material is tuned to a certain frequency of this energy and instead of trying to merely use the small amount of current that we are getting from these we need to actually tune these so as to be like an antenna.
I really could use everyone's help in this I have made a thread for the general Idea:
"Petrovoltaic Radiant Collector"
http://www.overunity.com/index.php?topic=8953.0
All I can mostly offer is my ideas and theoretical research into all this, as I am fairly poor/modest income with a little one on the way ;D So anyone who can help in studying this further and can confirm anything or help/discuss would be much appreciated.
I find it interesting to note also that Brown noticed changes in these materials depending on lunar/solar/gravitational etc changes. Note the thread:
"Earth Electrical Energy Datalogging Experiments"
http://www.overunity.com/index.php?topic=7769.0
This is all related IMHO.
Thank you
-Winter
Pirate88179
Ian and all:
Have you seen this video of a guy's crystal cell?
http://www.youtube.com/watch?v=_bmxIwgLYEY&feature=recentf
He says he is getting 1.2 volts and 3 mA's.  From the video, I believe he leaves out the high voltage part of the procedure.
Just thought you might want to check this out.
