Crystal Power CeLL by John Hutchison
Started by dani, April 26, 2006, 04:11:36 PM
das aloda bullspit
ok thankyou you are right it does take a long time to make these and even thogh i have verry powerful machines to do this it hasnt gone right you have all had mutch better outcomes than me but now i know where ive gone wrong i will keep trying and i know its hard with the money you have, it is for me aswell i only get this stuff om a science teacher of mine and whatnot  also ive tried noibium and it does work in a way with cells i had one upto 70kv on a  vandegraaff hybrid and I t was pretty good settled for a day and a half at 1.80 volts and then it dies i can give the ingeidients  but not the amounts not cos i cant tell you its that i didnt use measures but it was small
Barium titanate a bit of waterglass or borax to bind it together or your own choice its not exact any of this its only waht i used experiment with it ti may work it may not i dont know
Palladium, rhodinum,
pure silicon or germanium
Niobium
Bismuth as the rod
chalk
a tiny bit of tourmaline
flourite i think
and an aluminium manganese alloy tube
has anyone tried metglas adding to their cells as it is amphorus and has good magnetic and electric properties
Sorry to mean any incovienience for you alls
goodivenink
das aloda bullspit
had anyone tried scavenging old cpus from computers the 200 pin ones and stuff and sticking them on aluminium plates and putting alu foil around them and reading the voltage off them I did it once i science and my science teacher found this out by accident and it gave off a voltage in some places 0.09volts in others 0.89 volts nearly a volt this is an interesting phenom and if i get my cmaera working i will show you some picture of me with my cpu cells
This may be suing a similar effect to hutchinons cells but im not sure
also ive lowered the voltages on my machines and it kinda works but ive still got some bugs to iron out also has anyone tried any mixes of readily available  cheicals and mixing them with types of rocks to get a rock soup ?
Dont ..I did once and it sparked it was liea hutch cell upto the point it nearly set me on fire then it was just painful
ian middleton
G'day all,
@Das: yeh!, cells bursting into flames, I've heard of this  ;D ;D ;D
As for readily available chemicals, you can make a reasonable cell out of crushed clinker, washing soda, creme of tartar ( to make rochelle salt) and cement. I'll dig out the reciepe and post it up. It's very basic but it works, it will give you an unlimited supply of " very low power". ;D
@winter: Thanks for the JH youtube link. I watched it and quite frankly I was very disapointed.
Is that the best he can come up with after nearly 30 years work. I hope he doesn't use those needles for anything else. As for the CPU chips, nothing unusual about that. I was cutting the cans off 2N3055 transistors in 1975 and getting the same voltages. Anyway his use of wax in his needle cells suggest he is re-visting the work of TT Brown ie electrets.
If anyone is interested, do a bit of research on Antonio Meucci. You'll find a reference to him on John Bedini's site. His treatment of wires is very similar to what we are doing here.
Talking of cells bursting into flames, I re-measured the sulphur cell today and it was @ 0.151V after nearly 2 years.
I could be in for a good weekend, I have germanium and zinc oxide due to arrive any day so I can proceed with a new type of multicell.
As usual, keep up the good work.
catch you later
Ian
das aloda bullspit
IT didnt so much burst intoflames as the metal stsretd to go all soft and it bulged and as it got hotter a ark between the bismuth and alu started to form afetr about 4 seconds it explaoded and was at over 500 degrees wich is odd as i only had the ion induction heater upto 300 degrees and as soon as i put the electrostatic generator on it about 30 mins in that happened but it stragelt still produces a quite high voltage but i breaks  verry easily  i should've  added a binder with a low resistance but i coulnt find one then i thought borax or waterglass would do so i will come back to that one.Also its possible  that the cpu cell is taking advantage of an not well known phenom called electron inon bleedage whitch happens sometimes in CPU's and large storage devices as they get more complex into the billion transistor mark aswell as the dopants it could be acting like a verry low power psuedo crystal cell..also is it possible to add one or more and stack them together somehow to greate a big medium voltage battery suing only cpu's? i would like to know
ian middleton
G'day all,
@wozlzl: I think you may have taken a wrong turn when you logged on to the net this morning. But just in case you didn't, just be aware you are talking to a level 81 Paladin in Diablo II and I might have to zap you with a level 22 holy bolt if you don't keep on topic.
Now what was that you were saying about crystal cells ?  ;)
catch yer
Auralius (slayer)
