Crystal Power CeLL by John Hutchison
Started by dani, April 26, 2006, 04:11:36 PM
mrbr00k5
@Everyone
Sorry I haven't posted in a while, I was sick for a bit there. But I'm back in action now. ;D The cell I posted about that I made on 5/29/2010, the one with the Lepidolite and so on in it, is still working great, and so are my sealant cells. I made a cell with 3 AA battery size cells wired in series, and then I taped them all together into one cell. I put it on a direct short for awhile, and now it makes 2.10 Volts at 1.05 Milli-Amps. It has the same ingredients as the 5/29/2010 cell, except no Lepidolite, since I'm out of that mineral. I'll post a picture of it later, I've gotta go to work right now. ;)
das aloda bullspit
that is great nes my rock lumps are doing quite uell and are at around 0.4-0.6 volts added to all the cells i have made that uork the voltage is around nearly 30 volts and is pretty good at koen ho are your old cells orking are theystill uorking uell? uhats the voltage? and sutra i haerd you uere trying to make a galena pyrite tourmaline rochelle salt cell a fe months ago...ho are tese cells holding out at the moment please reply youto asi ould love tokno ho your getting on and your cells too. you still orking on those rock lumps? and conkrete ho are yourcells going at the moment? they still orking?
das aloda bullspit
oh you guys my cells are good at the moment and ho can you tell the difference beteen crystal poer cells and batteries in ther electical uays? is it something to do ith the voltage drop could you send me a picture of a galvanic batterys electrical signature and a crystal poer cells electrical signature? do yours heat up at all hen you short them anybody? mine dont realy get hot also i found out a tiny bit about a man called Sebatsion Duchmaine hoaz ho apparently in the 20s made a cell like a battery using metalic oxides titanates and other substancesand glass like substances hilst putting through a magnetic charge. could he be the true father of the crystal poer cell? not mutch is knon about hat happened from there on that as the only info i found on this guy and there is absolutely no info on this man on google also my cpu cell is still orking and is sound ho could it be orking as i kno that silicon is hat they put in solar cells but this is not exposed to the sun and is self contained ell 20 of them in a thick aluminium tube ith aboslutely no solar poer getting to them is this some other less knon oor even unknon effect the chip has lods of dopants in them at sutra are your galena tourmaline cells still orking and are yours too koen  keep up the good uork everybody :)
mrbr00k5
@Everyone
Hi everyone, I just wanted to share a little project I made. I took the cell I made on 5/29/2010, the Lepidolite Cell, and put it in a little box, with a joule thief, and connected it to a L.E.D., then put a nice big shiny red button on it! ;D I've attached some pics of part way through the wiring process, and then the finished project. And it works! I just thought it would be cool to have this little button you can press, and have a demo of free energy. So far it's doing well, I'll be checking on it once in awhile, to see if it still works, but I'm hopeful! ;)
conradelektro
@ mrbr00k5 - nice crystal cell and box - how long does the LED light when switched on (hours, days)?
About a month ago I posted a copper - tile cement - aluminium cell (see Reply #836 on: June 03, 2010, 11:00:24 AM and Reply #853 on: June 18, 2010, 10:44:34 AM in this thread).
This very simple cell is driving a Joule Thief with a red LED since one month continuously (no on-off-switch).
One has to dip the cell in water for a few seconds every 3 to 4 days to keep it going. In humid weather the "dip" is not necessary. The cell looks dry (after a "dip" it seems to be dry again within an hour) but obviously needs a little moisture (best from humid air).
So far no corrosion is visible and the metal sheets stay firmly glued to the tile cement.
The cell delivers about 0.3 mA at about 0.8 Volt continuously. One could of course build more layers and more cells to drive higher loads but I want to see first how the cell is holding out.
Greetings, Conrad
